How to test throttle position sensor?
Old Jul 15, 2003 | 03:45 PM
SpinMonster's Avatar
SpinMonster
Default How to test throttle position sensor?
My car is stumbling during cruise speeds during minute changes in throttle. This occurs even with cruise control engaged. Autotap shows no changes in ignition/fuel specs. The car ran fine for a while with current set-up and is progressively getting worse with these symptoms. Code 1514 gets set if I leave the 1514 table stock. I cleaned the maf with no change in symptoms. The parts involved, I beleive are MAF assembly,TAC module, and the TB. I suspect the TP sensor but don't know how to test it for proper performance. The title of cheif TP sensor tester goes to the person that solves this puzzle as well as my gratitude. :skep:
Old Jul 15, 2003 | 05:06 PM
SpinMonster
Default Re: How to test throttle position sensor? (SpinMonster)
Traction control system gets disabled also if 1514 table is left stock
Old Jul 15, 2003 | 06:30 PM
Bink's Avatar
Bink
Cruise-In V Veteran
St. Jude Donor '09
TPsensor is on a 5V reference circuit. Max output is 4.6V (from ls1tech). You should be able to log voltage of TPSensor with Autotap. Hope this helps some. :yesnod:
Old Jul 15, 2003 | 07:22 PM
Mike Morgan's Avatar
Mike Morgan
Need to know more about the car. My guess is a leak somewhere in the intake tract, faulty MAF or bad O2 sensors. Check the fuel trims in cruise if they are high positive then one of those three are your problem.
To How to test throttle position sensor?
