C5 Power Plate pictures
Old Jul 16, 2003 | 01:54 PM
dmcantrell's Avatar
dmcantrell
Default C5 Power Plate pictures
This is in response to the C5 Power Plate thread below.
--dc.
Old Jul 16, 2003 | 02:08 PM
AC54ME's Avatar
AC54ME
CI 6-7-8-9 Veteran
CI-VI Car Show Winner
St. Jude Donor '07-'08-'09-'10-'11-'12-'13
Default Re: C5 Power Plate pictures (dmcantrell)
You forgot to include the thread.
Old Jul 16, 2003 | 02:48 PM
dmcantrell's Avatar
dmcantrell
Default Re: C5 Power Plate pictures (AC54ME)
OOPS!! :eek:
http://forums.corvetteforum.com/zero...=605205&page=1
Old Jul 16, 2003 | 03:26 PM
tbyrne's Avatar
tbyrne
From: Westport, MA. www.tbyrnemotorsports.com - 1-877-4-TBYRNE
St. Jude Donor '06-'07
Pretty much the same as the throttlebody spacer that we use in the trucks. Most people see a horsepower gain from this and everyone usually sees gas mileage improvement.
Any noise from this one?
Old Jul 16, 2003 | 03:29 PM
dmcantrell's Avatar
dmcantrell
Default Re: C5 Power Plate pictures (tbyrne)
I have no idea. I personally do not have this mod on my car.
You might call John at 21st Century Muscle Cars and ask him -- he's seen more of them than the rest of us.
--dc.
Old Jul 16, 2003 | 03:50 PM
kromberg's Avatar
kromberg
:skep:
Keith
Old Jul 16, 2003 | 05:14 PM
Smoke-N-Shot's Avatar
Smoke-N-Shot
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In VI Veteran
Interesting... If this does what it says it does than I would say it is one of the most HP gain for the money... Lets hope it is all real...
Old Jul 16, 2003 | 05:56 PM
verskel's Avatar
verskel
Default Re: C5 Power Plate pictures (Smoke-N-Shot)
It's "REAL" for cars that haven't already did the LS6 intake mod.....
Now, to make my story really fishy - I was going to post my Dyno Sheet, but I left the dang thing at Hooters last night......went back & it was gone !!! :eek:
Old Jul 16, 2003 | 09:00 PM
JBS11's Avatar
JBS11
Looks exactly like a carb spacer...
Old Jul 16, 2003 | 09:18 PM
TimC5's Avatar
TimC5
Default Re: C5 Power Plate pictures (verskel)
"Now, to make my story really fishy - I was going to post my Dyno Sheet, but I left the dang thing at Hooters last night......went back & it was gone !!! "
Did you look between the *****???? :reddevil
Old Jul 16, 2003 | 11:11 PM
los7883's Avatar
los7883
Default Re: C5 Power Plate pictures (TimC5)
So do you think this mod wouldn't help if you have a LS6 intake? They're pretty close as far as hp right? 8-10...???
Old Jul 17, 2003 | 12:11 AM
rodney@rpmtransmissions's Avatar
0rodney@rpmtransmissions
Former Vendor
Default Re: C5 Power Plate pictures (los7883)
Looks like a good spot to drill and tap a couple fogger nozzle holes :D
Old Jul 17, 2003 | 12:26 AM
H82BFST's Avatar
H82BFST
I know how MUCH you guys want to believe in products like this, but come on guys, GENUINE 20HP+ is had from MAJOR mods like heads or some cams.
If this mod gave someone 20HP or any HP at all, it's probably just a bandaide that happened to FIX either a poor tune, a vac leak at the TB or something else. If it does give you power instantly, it probably gets learned out by the PCM fairly quickly.
I know I may be bursting a few bubbles here, but just like there is NO VIRTUAL HORSEPOWER added from rear end gear change, this one is just a fantasy...
Sorry, one dyno swap done 20 minutes appart definitely doesn't tell me anything. It could of simply been a hot run on the 1st pull with a lot of timing pulled from KR or any number of reasons... come on....
...am I the only non believer on this board?
Old Jul 17, 2003 | 12:35 AM
H82BFST's Avatar
H82BFST
Default Re: C5 Power Plate pictures (H82BFST)
Actually, taking a second look at the piece, maybe you are introducing a vac leak at the TB/intake and it may temporary lean you out until the ltrims shoot up and learn out... So, I guess if your stock program ran a little rich, then yeah it'll find some power on the dyno for a pull or two.
How does the TB and this plate side seal? Does this plate have a ridge on one side for a factory like o-ring seal?
[Modified by H82BFST, 5:37 AM 7/17/2003]
Old Jul 17, 2003 | 12:44 AM
Barely Legal's Avatar
Barely Legal
A vacuum leak won't change the HP really. Unmetered air will. :auto:
Old Jul 17, 2003 | 06:29 AM
vetteman21's Avatar
vetteman21
my uneducated guess as to why this would work is. an ls6 manifold has more cubic space for on demand oxygen uninhibited by the throtlebody. The spacer in essence does the same thing. the manifolds upside is the space is built in to the design with smootheness. that is what the ribs are trying to recreate. I think gm got the ls6 manifold just right and that is why you dont see many aftermarket manifolds much different from it. I think the reason you dont see an improvement with a bigger cam with this spacer is due to the better smoothenes of the ls6 intake. but what do I know... :hat
Old Jul 17, 2003 | 08:13 AM
Smoke-N-Shot
Default Re: C5 Power Plate pictures (Crashed 94)
:withstupid:
Nick
To C5 Power Plate pictures
Old Jul 17, 2003 | 08:41 AM
NOEXCUSES's Avatar
NOEXCUSES
You want to make a friendly wager??
[Modified by NOEXCUSES, 7:42 AM 7/17/2003]
Old Jul 17, 2003 | 10:07 AM
H82BFST's Avatar
H82BFST
Default Re: C5 Power Plate pictures (Barely Legal)
" vacuum leak won't change the HP really. Unmetered air will. "
So you consider a leak after the MAF to not be unmetered air eh?
[Modified by H82BFST, 3:57 PM 7/17/2003]
Old Jul 17, 2003 | 10:12 AM
H82BFST's Avatar
H82BFST
Default Re: C5 Power Plate pictures (NOEXCUSES)
Noexcuses - This is simple, forget the dyno, go to the track. Change it out there back and forth between runs. 20HP+ to the wheels will be very evident in MPH.
I can't believe a vendor is willing to bet that this piece makes a REALLY 20HP+ to the ground (or 30HP+ at the motor)...
I may be able to buy the more plenum volume explaination or even increase velocity because of reduce diameter of throat, but 20HP at the rear wheels... puff puff pass
