Rough When Turned Off
Old Jul 16, 2003 | 06:54 PM
Sweet98's Avatar
Sweet98
Default Rough When Turned Off
When I shut my 98 LS1 engine off, it shuts off rough.. a little like an old carb would try to keep running. It only has 40k on it and zero mods and no accesories on when i shutt off, do i need a tune up?
Old Jul 16, 2003 | 07:59 PM
irfgt's Avatar
irfgt
Default Re: Rough When Turned Off (Sweet98)
I doubt if tuning will help your situation. It sounds as though you may have some low octane fuel, excess carbon buildup in your cylinders, excessively high idle speed, or some dirty or leaking fuel injectors. When you shut your engine off you no longer have spark to your plugs so that eliminates a tuning problem.
Old Jul 17, 2003 | 03:38 AM
RCswish's Avatar
RCswish
Default Re: Rough When Turned Off (irfgt)
There is NOTHING wrong with your car. You have a stick shift don't you??? That is just how the 6spds shut down when you turn the car off. Put the clutch to the floor when you turn the car off and the lugging down will be reduced. That is completely natural for yoru vette to do.
Welcome to the Forum :seeya
Robert
Old Jul 17, 2003 | 07:40 AM
Sweet98's Avatar
Sweet98
Ah,so most turn off like this then I guess...
Old Jul 17, 2003 | 07:01 PM
irfgt's Avatar
irfgt
My engine stops immediately when shut off. Rear end leaks like hell but the engine runs and stops great!
Old Jul 17, 2003 | 09:48 PM
Mick_S3's Avatar
Mick_S3
:lolg:
I love Vettes!
:leaving:
[Modified by Mick_S3, 2:49 AM 7/18/2003]
Old Jul 17, 2003 | 10:59 PM
aaaaa's Avatar
aaaaa
mine too!
Old Jul 17, 2003 | 11:35 PM
Vette Stripes's Avatar
0Vette Stripes
Former Vendor
St. Jude Donor '03-'04-'05-'06-'07-'08
Default Re: Rough When Turned Off (aaaaa)
Mine is a little
Old Jul 18, 2003 | 10:59 AM
Sweet98's Avatar
Sweet98
Default Re: Rough When Turned Off (mike76002)
If I turn it off imediately when i put it in park its ok. If i leave it sit a minute then turn it off, then its rough. The idle seems normally low and running fine.
Old Jul 18, 2003 | 08:49 PM
Wadoka's Avatar
Wadoka
Cruise-In 1-2-3-4-5 Veteran
My '99 six-speed shudders just a little when I shut the car down. Clutch to the floor, trans in reverse.
Old Jul 11, 2023 | 05:00 PM
RoxyRose's Avatar
RoxyRose
1st Gear
Default Rough shut off
mine too!
Not to revive an old thread, but came here seeking information and only responses i see are for manuals, mine does this too and it's an automatic.
Old Jul 11, 2023 | 06:05 PM
Dads2kconvertible's Avatar
Dads2kconvertible
Post two gives some good things to check.
To Rough When Turned Off
