TIRE Schraeder Valve Thread Size
Old Jul 16, 2003 | 07:27 PM
C4TOMCAT's Avatar
C4TOMCAT
Default TIRE Schraeder Valve Thread Size
Does anyone know the thread size MM or inch for the schreader valves used in tires. I need to know and cannot find it listed anywhere. thanks in advance. tom
Old Jul 16, 2003 | 07:43 PM
Face's Avatar
Face
Default Re: TIRE Schraeder Valve Thread Size (C4TOMCAT)
I've just picked up whatever size K-Mart and Pep Boys usually stock and it was correct.
Old Jul 16, 2003 | 07:47 PM
C4TOMCAT's Avatar
C4TOMCAT
Default Re: TIRE Schraeder Valve Thread Size (Face)
Well, I need to know what the thread pitch is in mm or in. I do not have that size in my tool kit or tap set. any help is appreciated. tom
[Modified by C4TOMCAT, 7:48 PM 7/16/2003]
Old Jul 16, 2003 | 08:08 PM
Wadoka's Avatar
Wadoka
St. Jude Donor '03-'04
Cruise-In 1-2-3-4-5 Veteran
7.7 mm OD
32 tpi, or 0.794 mm pitch
Minor diameter is 6.9
Thread designation is .305-32 or 7.7-32
A 5/16-32 nut might fit...if you could find one. Those are pretty rare as well.
Thank the Duryea brothers for such a whacked-out designation.
[Modified by Matt Black, 7:10 PM 7/16/2003]
Old Jul 16, 2003 | 08:47 PM
C4TOMCAT's Avatar
C4TOMCAT
Default Re: TIRE Schraeder Valve Thread Size (Matt Black)
MatBlack...........thanks for the info....looks like what I was looking for....this is for the tire stems INSIDE thread for the schraeder valve ...right. thanks tom
Old Jul 16, 2003 | 08:53 PM
Flyin'Brian's Avatar
Flyin'Brian
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
I would say not.
Looks like the specs for the nut and outside of stem to me.
Old Jul 16, 2003 | 09:19 PM
C4TOMCAT's Avatar
C4TOMCAT
Default Re: TIRE Schraeder Valve Thread Size (Flyin'Brian)
Well...after relooking at it you are probably right FLYINBRIAN...thanks for the heads up on that...I will keep looking....maybe someone will chime in...if not maybe the TireRack or supplier can answer my needs. tom
Old Jul 16, 2003 | 09:28 PM
Wadoka's Avatar
Wadoka
Okay, hang on, the inside thread for the valve stem core is a 0.209 x 36. Both are UNS 60 degree forms.
It's close to a 7/32-36 UNEF screw.
I always think about the outside first. That's what I bugger up.
BTW, you're not having any luck with web searches because you're mis-spelling "Schrader". Probably. Keywords are: Shrader Valve Stem Thread Pitch and you get a link to the Engineering Forum at Eng-Tips.com.
[Modified by Matt Black, 8:35 PM 7/16/2003]
Old Jul 16, 2003 | 09:35 PM
C4TOMCAT's Avatar
C4TOMCAT
Ok, thanks again...I will bookmark that site....till later Tom
To TIRE Schraeder Valve Thread Size
