Tire Pressure Sensor Question..
Old Jul 17, 2003 | 04:18 PM
LPDesRoche's Avatar
LPDesRoche
Default Tire Pressure Sensor Question..
I recently purchased a set of Z06 take off rims. What would happen if I installed them with out the sensors, would I get an annoying error message in the DIC? Or would I just not be able to pull up the pressures when I try? OR worse yet get the annoying check engine light?
Anyone??
Old Jul 17, 2003 | 04:23 PM
Y2Kvert4me's Avatar
Y2Kvert4me
CI 6-7-8-9-10 Veteran
St. Jude Donor '03
Default Re: Tire Pressure Sensor Question.. (LPDesRoche)
You will get a "svc tire mon sys" error on the DIC everytime you start the car. You can just reset it and go..not a terribly big deal, but an annoyance nonetheless.
A dealer Or someone with a Tech2 programmer) can program out the TPS system on a 2001 or newer C5's, but not on the earlier models.
:cheers:
davidcheese's Avatar
davidcheese
I just put on a different set of wheels with different sensors. Since the car cannot locate the sensors I do get an intermittent message......"Service tire pressure monitoring system" or something like that.
Old Jul 17, 2003 | 04:25 PM
Avanti's Avatar
Avanti
They will take stock sensors. I'm in the process of finding the part# for the sensors and nuts and putting on my newly customized Z06 wheels. The sensory technology is just too useful, imho, to forego.
All the best. :yesnod:
[Modified by Avanti, 4:14 PM 7/17/2003]
Old Jul 18, 2003 | 01:58 AM
Blackjetvette97's Avatar
Blackjetvette97
Default Re: Tire Pressure Sensor Question.. (Avanti)
Hi all,
I would like to change out one of my TPS's since it is dead now. Is this hard to do or technical? Can I take it to Firestone(I had Firehawks put on) and have them dismount the tire for me to switch out TPS? Thanks for any help.
Steve
To Tire Pressure Sensor Question..
