Bleed w/regular brake fluid first then with ATE?
Old Jul 18, 2003 | 04:04 PM
RoadVette's Avatar
RoadVette
Default Bleed w/regular brake fluid first then with ATE?
Hey guys,
I am about ready to bleed my brakes and have a Q. I noticed on prior posts that several people had to bleed their brakes several times. My question is should I use regular brake fluid first until I am sure I will not need to bleed again, and then use the ATE superblue? Thanks for your help!
Old Jul 18, 2003 | 06:49 PM
Richin Chicago's Avatar
Richin Chicago
Default Re: Bleed w/regular brake fluid first then with ATE? (RoadVette)
Hey guys,
I'm not what that would accomplish. You would still be chasing regular fluid with high temp fluid. Superblue is easy to see a color change with so you know when you cleared a particular line. The only thing you are not going to clear is the ABS unit.
Old Jul 18, 2003 | 08:29 PM
RoadVette's Avatar
RoadVette
Thanks Rich!
Old Jul 18, 2003 | 08:36 PM
Richin Chicago
Thanks Rich!
No problem. You may have seen this. Get a turkey baster and empty out most of the fluid in the reservoir. It will really eliminate a lot of pumping.
[Modified by Richin Chicago, 7:37 PM 7/18/2003]
Old Jul 18, 2003 | 08:48 PM
LoneStarFRC's Avatar
LoneStarFRC
Default Re: Bleed w/regular brake fluid first then with ATE? (Richin Chicago)
And install speedbleeders! Greatest things since sliced bread! :yesnod:
Old Jul 18, 2003 | 08:56 PM
Richin Chicago
Default Re: Bleed w/regular brake fluid first then with ATE? (LoneStarFRC)
:iagree:
http://www.speedbleeder.com/
To Bleed w/regular brake fluid first then with ATE?
