Check engne light on
Old Jul 19, 2003 | 06:37 PM
TOPGUN9's Avatar
TOPGUN9
Default Check engne light on
My check engine light won't go out. Here are the codes: 10-PCM P0161 H C
28-TCS C 1225 H
Any ideas? Can one of you guys interpret these codes? :confused:
Old Jul 19, 2003 | 09:59 PM
Zturb00's Avatar
Zturb00
Default Re: Check engne light on (TOPGUN9)
10-PCM P0161 H C means, ''heated oxygen sensor. heater circuit bank 2 sensor 2''
the other one ? dat ends in da ''H''.
should be ignored.
as the list says;
''any code that ends in an H. is a code that was registered previously, but is no longer an issue''....
[Modified by Zturb00, 10:00 PM 7/19/2003]
Old Jul 19, 2003 | 10:50 PM
TOPGUN9's Avatar
TOPGUN9
Default Re: Check engne light on (Zturb00)
Thanks! :cool:
Old Jul 19, 2003 | 11:16 PM
wkasak_07Z06's Avatar
wkasak_07Z06
For future reference...https://www.corvetteforum.com/techti...D=26&TopicID=1
:cheers:
[Modified by wkasak_98Coupe, 11:17 PM 7/19/2003]
To Check engne light on
