getting code p1870 >????
Old Jul 20, 2003 | 01:33 PM
blue98coupe's Avatar
blue98coupe
Default getting code p1870 >????
not sure what this code is ,any help ?? thanks
Old Jul 20, 2003 | 02:12 PM
vetteshop's Avatar
0vetteshop
Former Vendor
St. Jude Donor '13
Default Re: getting code p1870 >???? (blue98coupe)
Did you change the rear end ratio???
Old Jul 20, 2003 | 02:29 PM
SFVetteman's Avatar
SFVetteman
P1870 is "transmission component slipping"
If you have changed your differential gear ratio without reprogramming then this code will pop up. Otherwise, it is probably your transmission crying uncle.
About the 3rd time I launched my car after getting my heads and cam, I started getting this code. The stock A4 can barely handle a stock motor.
Old Jul 20, 2003 | 02:48 PM
blue98coupe
Default Re: getting code p1870 >???? (SFVetteman)
yep went from 3:15 to 3:42 ,I am going to be needing an upgrade anyway on the tranny with the magna charger thanks for the input .Oh and C5 TECH that steering wheel was 360 degrees off thanks again :cheers:
Old Jul 20, 2003 | 03:00 PM
mapman's Avatar
mapman
The Powertrain Control Module (PCM) has detected excessive Torque Converter Clutch (TCC) slip.
The PCM will inhibit TCC engagement when this code it set, transmission adapt functions are frozen,etc. The operating conditions when the code was set are stored as Freeze Frame and Failure Records, so don't reset the DTC . A mechanic with a scan tool can extract the information in the Freeze Frame and Failure Records. It may take multiple TCC cycles to verify a slipping condition.
Bronze material in the transmission oil pan may indicate stator shaft bushing wear.
The transmission fluid level is correct?
To getting code p1870 >????
