Key fob programming instructions
Old Jul 20, 2003 | 02:57 PM
goalie31's Avatar
goalie31
Default Key fob programming instructions
Just bought a 99 C5 convertible. The fob battery was dead and I don't have an owners manual. Can someone send me the programming proceedure? I assume it's similar to the C4?? Just traded the C4.
Thanks,
Bill Ankerholtz
[Modified by goalie31, 7:57 PM 7/20/2003]
Old Jul 20, 2003 | 02:58 PM
pewter99's Avatar
pewter99
St. Jude 15 Year Donor
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
Default Re: Key fob programming instructions (goalie31)
put key in ignition turn on to ACC... hold down both buttons till horn beeps..I do believe
Old Jul 20, 2003 | 02:59 PM
goalie31's Avatar
goalie31
Not to sound dumb, butt which 2 buttons?
Old Jul 20, 2003 | 03:00 PM
pewter99's Avatar
pewter99
lock /unlock :lol: ..sorry
Old Jul 20, 2003 | 05:46 PM
pewter99's Avatar
pewter99
Default Re: Key fob programming instructions (pewter99)
did it work?? :lurk:
Old Jul 20, 2003 | 07:05 PM
goalie31's Avatar
goalie31
Didn't work. Just to make sure, the positive side of the fob batterey faces up right? (battery # showing). Turned the key to acc, pushed the lock and unlock buttons at the same time. No sounds or anything. Does the position of the passive on/off slide affect it?
Old Jul 20, 2003 | 08:38 PM
goalie31's Avatar
goalie31
It Works!!! Thanks. Another question; Is it supposed to unlock both doors?
Old Jul 20, 2003 | 11:19 PM
vetteman21's Avatar
vetteman21
sweet! I waisted money having the dealership do it a couple times before. Seems they coulda just told me this as a curtousey! :mad Thanks for the info :cheers:
Old Jul 21, 2003 | 05:28 AM
pewter99's Avatar
pewter99
you can go into options on the DIC and select unlock both or drivers only...glad it worked for ya I was thinking last night that I skipped a step... :lol:
Old Jul 21, 2003 | 06:25 AM
Bill96LT4's Avatar
Bill96LT4
Bill
I just had to reprogram both fobs. I tis fairly simple to do. If you have two fobs, you will need to have both handy. Put key in ignition and set to ON. In DIC select options and scroll thru until you have a blank screen. Then press and hold the reset button until FOB LEARNING appears on the DIC screen. YOu'll be prompted to press and hold the lock and unlock buttons on FOB 1, and then FOB 2. That's all there is to it.
Good Luck
Bill
Old Jul 21, 2003 | 07:46 AM
WILDONETHIRTYSEVEN's Avatar
WILDONETHIRTYSEVEN
If you ever forget, I believe it is in section 2-10 in the operations manuel under FOB taining. :smash:
To Key fob programming instructions
