Where is the remote module/antenna located?
Old Jul 21, 2003 | 02:00 PM
turmat's Avatar
turmat
Default Where is the remote module/antenna located?
:confused: Since getting back from a long cruise to PA/NY, (worst roads I ever saw on I-86!), both of my key fobs stopped working. My front tire pressure sensors are out also. I am suspecting a loose wire on the remote module due to the ungodly bouncing or a antenna problem. Anyway, it seems unlikly that they ALL would go out at once. Does anyone know where the module is located and how it is accessed? :D Any help is greatly appreciated. :cheers:
Old Jul 21, 2003 | 03:32 PM
turmat's Avatar
turmat
Default Re: Where is the remote module/antenna located? (turmat)
TTT
Anybody???????
Old Jul 21, 2003 | 04:06 PM
ROCKnROLL's Avatar
ROCKnROLL
Veteran
i believe the receiver is located in the rear wheel well on the driver side.
Old Jul 21, 2003 | 04:25 PM
GraveDigger's Avatar
GraveDigger
Default Re: Where is the remote module/antenna located? (ROCKnROLL)
It's behind the carpet around the gas fill or higher on the drivers side.
Old Jul 21, 2003 | 05:34 PM
ROCKnROLL's Avatar
ROCKnROLL
Veteran
i just looked it up in my 98 GM service manual and it says to access the receiver you must "remove the left rear wheel tub trim plate".
Old Jul 21, 2003 | 05:40 PM
turmat's Avatar
turmat
:D Thanks for all of your input. I will keep you up to speed! :thumbs: :hat
Old Aug 31, 2023 | 04:02 PM
Gerald Potts's Avatar
Gerald Potts
1st Gear
thank you very much found receiver replaced it & got key fobs programed
To Where is the remote module/antenna located?
