Headlights not popping up!
Old Jul 22, 2003 | 09:16 AM
DarkGreenC5's Avatar
DarkGreenC5
Default Headlights not popping up!
My headlights are now intermittently not popping up. Sometimes the first turn of the swtich they're fine, other times it takes 3, 4, 5 or more turns of the switch before they pop up.
Anybody have this problem? Could it be just the switch failing slowly?
Thanks,
Randy :cheers:
[Modified by DarkGreenC5, 3:39 PM 7/22/2003]
Old Jul 22, 2003 | 09:03 PM
Evil-Twin's Avatar
Evil-Twin
St. Jude Donor '03-'04
Default Re: Headlights not popping up! (DarkGreenC5)
yes
Old Jul 22, 2003 | 09:06 PM
Tiger Shark's Avatar
Tiger Shark
It could be the actuator (motor). Sounds like the gear has worn down. If it's under warranty, you can get it replaced for free. If it's out of warranty, it's around $280 to replace OR someone here sells new gears made out of brass.
Old Jul 22, 2003 | 09:11 PM
Tiger Shark
Here's the thread about the brass gear: http://forums.corvetteforum.com/zerothread?id=583380 :cheers:
Old Jul 23, 2003 | 08:41 AM
DarkGreenC5
Default Re: Headlights not popping up! (Tiger Shark)
Thanks for the help, guys!
Randy
Old Jul 23, 2003 | 09:40 AM
Tiger Shark
Glad to help! :cheers:
Old Jul 23, 2003 | 01:54 PM
mapman's Avatar
mapman
DTC codes?
Old Jul 24, 2003 | 04:08 PM
LoneStarVette's Avatar
LoneStarVette
Just had both mine replaced @ Corvettes of Houston as well as my rocking seat and the best of all...under extended warranty. Once again Paul @ COH was the man!!!!
Bob
To Headlights not popping up!
