Check Engine Light
Old Jul 23, 2003 | 12:59 PM
muchomanos's Avatar
muchomanos
6th Gear
Default Check Engine Light
Car runs fine but light is on- smell gas from time to time when I get on it- is this common problem?
Old Jul 23, 2003 | 01:46 PM
jackalope's Avatar
jackalope
6th Gear
Default Re: Check Engine Light (muchomanos)
Use the procedure listed in the link below to get the trouble code being generated, that should help tell you what's going on:
http://www.c5forum.com/ayc/dtcdic.php
Old Jul 23, 2003 | 08:33 PM
muchomanos's Avatar
muchomanos
6th Gear
Default Re: Check Engine Light (jackalope)
Thanks, very helpful
Looks like I have a small leak in the emissions system, explaining the gas smell
Old Jul 23, 2003 | 08:56 PM
Buckmaster's Avatar
Buckmaster
Cruise-In III Veteran
Cruise-In V Veteran
St. Jude Donor '03-'04
Any codes?
Old Jul 24, 2003 | 10:47 AM
muchomanos's Avatar
muchomanos
6th Gear
Default Re: Check Engine Light (Buckmaster)
Yup-
Code is PO442 EVAP small leak detected
Any ideas where to start look?
Old Jul 24, 2003 | 11:32 AM
Fang S-289's Avatar
Fang S-289
This is a timely thread for me. I recently got the "Check Engine" light and took the car in to have it checked. The code was P0441-Evap System No Flow During Purge. The diagnosis revealed no problem. OK, these things happen. About a week later i got the "Check Engine" light again. Took the car to a different mechenic. The code was the same and the diagnosis was the same. No problem was detected. (Total cost thus far, about $200) I have learned how to access the codes myself on the DIC now. My question is: If I get a "Check Engine" light again and I determine that it it the same code that triggered the light, is there any way I can turn off the "Check Engine" light myself?
Thanks in advance for any suggestions. :confused:
Old Jul 24, 2003 | 01:49 PM
georgec114's Avatar
georgec114
Check your gas cap...Make sure it's on tight or look for a torn or missing
gasket. Same thing happened on my Grand Prix.
Good Luck...
Old Jul 24, 2003 | 01:59 PM
Buckmaster's Avatar
Buckmaster
Cruise-In V Veteran
Check the gas cap. Be suprised how often this happens.
To Check Engine Light
