PCM editing
Old Jul 23, 2003 | 05:58 PM
verskel's Avatar
verskel
Default PCM editing
Okay, there has to be at least a few speed~tech junkies on this board that "tweaks" his own ride by re-programming the PCM. :crazy:
IF you get the LS1 edit program (save your current settings for a baseline) and do 'minor' changes..... what are your options to record performance ?
The only sure way that I know of is a Dyno. Someone told me about "EFI" or a recorder that documents your #'s while driving. Any suggestions ?!?
Old Jul 23, 2003 | 06:04 PM
Godspeed's Avatar
Godspeed
Senior Member
Cruise-In III Veteran
Cruise-In IV Veteran
Default Re: PCM editing (verskel)
I personally like to use the GM Tech 2 for diagnostics. If you don't have access to one there are several good software packages that run on a standard laptop.
http://www.autotap.com http://www.easediagnostics.com http://www.efilive.com
Old Jul 23, 2003 | 06:12 PM
verskel's Avatar
verskel
Default Re: PCM editing (Godspeed)
Thank you ! ....you da man :D :thumbs:
To PCM editing
