Accusump Installation
Old Jul 23, 2003 | 11:47 PM
Z06Plasticfantastic's Avatar
Z06Plasticfantastic
Default Accusump Installation
Anybody install and accusump and if so, how and where did you mount it?
Old Jul 24, 2003 | 03:50 AM
vette.se's Avatar
vette.se
Default Re: Accusump Installation (Z06Plasticfantastic)
I think you will find some info if searching the Autocross & Roadracing section.
I installed mine under the frame in the front (you have a lot of free space to use)
:cheers:
Old Jul 24, 2003 | 02:06 PM
Stephen L's Avatar
Stephen L
Default Re: Accusump Installation (vette.se)
I agree. Mine is in the same place.
Remove the air intake box and the plastic shield on the top/front of the radiator (easiest to remove from below the car). This will expose the back of the front bumper cross member and there is plenty of space to mount a 3 quart accusump. You will need an electric valve and I highly recommend running an auxillary air line from the sump to somewhere easily reachable. That way you can locate the pressure gauge in an easy to reach location and you can add air if necessary without removing the air filter and radiator cover.
It works great! Hit the switch and the oil pressure gauge will read 30 psi before the engine even starts.
Let me know if you need any more details.
Steve
Old Jul 25, 2003 | 09:49 PM
Z06Plasticfantastic
Default Re: Accusump Installation (Stephen L)
Thanks for the great info. Any pics? A couple of additional questions: Did you fabricate your own mounting brackets or modify the Accusump SS brackets that are availabe; How did you mount the brackets-TORX bolt, Aircraft Grade SS or weld them on, and what power or circuit did you run the electrical switch off of. Did you route it to connect with the ignition switch or is it wired to its on off/on switch? Do you need a separate circuit or breaker for the accusump?
Old Jul 26, 2003 | 06:15 AM
vette.se's Avatar
vette.se
I used the ones that came with the Accusump and bolted them to two 20cm*5cm*4mm aluminum pieces. To mount the unit I used the 'press-in' style threaded nut (I do no know that its called) and mounted them to the underside of the front frame.
For the power I used a connection in the fusebox in the engine compartment and I have a switch in the ashtray.
If you do not use a switch and leaving the ignition on (before starting the car) will cause the accusump oil to drain to the pan overfilling it. The recommendation I got from DRM is to start the engine and when power on the Accusump. When shutting down first power down the Accusump and when turn the ignition off.
(excuse my bad english, I hope you get what I'm trying to say :))
:cheers:
Old Jul 30, 2003 | 12:13 AM
Z06Plasticfantastic
How did you route the accusump wiring into the interior?
Old Jul 30, 2003 | 01:54 AM
BoeingFlyer's Avatar
BoeingFlyer
5th Gear
Can anyone post pictures of their instalations...
thanks
Matt
Old Jul 30, 2003 | 10:29 AM
vette.se's Avatar
vette.se
Behind the battery you have a rubber grommit? I had no problem pulling the new cables through.
:cheers:
To Accusump Installation
