Memory package....qustion
Old Jul 24, 2003 | 04:17 PM
movinlow's Avatar
movinlow
Default Memory package....qustion
I did a search but didn't find anything relating to my problem. I replaced my 98 coupes battery, got a Optima Red top...now when I put my key in for some reason memory #2 starts to go...I don't want the number 2 memory to go to it's settings....how to I stop this from happening...didn't find anything about it in the manual...thanks..
Old Jul 24, 2003 | 11:07 PM
WhiteC5Vette's Avatar
WhiteC5Vette
St. Jude Contributor
Default Re: Memory package....qustion (movinlow)
I would try re-syncronizing both remotes.
Stand within 5 ft from the vehicle.
Simultaneously press and hold the LOCK and UNLOCK buttons on the transmitter for 7 seconds.The horn should chirp in order to confirm synchronization.
If that does not work try reprogramming both of them:
Turn the ignition to ON.
Turn the radio to OFF.
Press the RESET button on the driver information center (DIC) in order to clear any IPC warning messages.
Press and release the OPTIONS button on the DIC to scroll through the display options until the IPC display is blank.
Press and hold the RESET button for 3 seconds.
Press the OPTIONS button until FOB TRAINING message is displayed.
Important
If the FOB TRAINING message cannot be display, check if the BCM is configured with the correct RPO codes.
Press the RESET button in order to begin the programming sequence. The message HOLD LK + UNLK 1ST FOB will be displayed.
Simultaneously press and hold the LOCK and UNLOCK buttons on the first transmitter for 15 seconds. The IPC will indicate when that transmitter is programmed and when to proceed to the next. Repeat this procedure for each additional transmitter or press the OPTIONS button to exit.
