same cooling problem only worse
Both cooling fans do come on at these temperatures?
Ground (102) for the fans is good? (Frame rail passenger's side engine compartment)
Have you tested the thermostat to see if it opens at the specified temperature?
Did you experience these temperatures before you had the underdrive pully?
also you may have a colapsed radiator hose... or two.. it is hard to tell visually... if it were me... I would preplace them...
[Modified by Evil-Twin, 2:07 PM 7/25/2003]fans come on at 130??????? thats way too low.. that means they are always on..... if you have a 160 stat and it tests out at 160.. fans should come on around 180 and off at 170...
[Modified by Evil-Twin, 2:10 PM 7/25/2003]
a1rdcm
b2283h
b2285h
u1064h
a6scm
b0851h
b2605h
aoldcm
b2252h
b2204h
b2282h
b2284h
b2262h
b2264h
u1064h
60ipc
b0521h
u1040h
u1160h
10pcm
p0137h
p0138h
p0140h
p0141h c
p0158h
Thanks for any help!!!!
a1rdcm: right door control module - U1064 is a communication problem with the Body Control Module (BCM), the others are battery voltage out of range
a6scm: seat control module - battery out of range and a seat position problem.
aoldcm: left door control module: door key cylinder, battery voltage, and mirror position.
60ipc: instrument panel cluster: Tach signal malfunction, The "U" DTC relate to communication problems with the electronic brake control module and the driver door module with the instrument panel cluster.
10pcm: Powertrain Control Module - These codes relate to the heated O2 sensors (HO2S) - probably related to your headers.
Did your Samco hoses have reinforcing coil springs inside the hose?
On C3s the lower radiator hose can collapse if the hose is not internally supported. When this hose collapses, coolant can't flow and the engine heats up. Some coolant hoses don't have the needed reinforcing coil springs.
I would replace the thermostat with the standard 190F one from GM. I would also replace the current hoses with standard GM hoses. Buy them at the Chevy dealer! What you want to do is return the car to a "stock" configuration in order to sort out the problem. (50/50 DexCool)
The under-drive pulley might have some effect, but the problem may just be a collapsing radiator hose, as the fans seem to be working. If it isn't the hoses, the water pump would be the next obvious player. Try the inexpensive stuff first. :)
[Modified by mapman, 5:08 PM 7/25/2003]
Thanks for the replys. Actually I can drive on the freeway all day and I stay at 215 give or take and 235ish on the oil. Its just when I stop the fan shuts off and the coolant starts to boil. Are the fans suppost to shut off immediatly. I pretty much had the same problem a couple years ago and putting the cooler tstat solved it. It may be a 178 I forget. The tstat staying opens sounds like it may be the culprit(who knows). It usually takes around an hour to get up to these points.
I suggest going back to stock thermostat and get the fan kick on temp reprogrammed to 220 or so. There are many known problems with aftermarket thermostats.
You also mentioned that you have more water in the system. Did you mod anything there??? Couldn't find any post about this.
Also, you still run 50/50 mix Dexcool/water? Dexcool raises the boiling point.
Hope this helps.
1) is coolant flowing - i.e., water pump function and thermostat opening
2) if 1 is good - visually compare flow to another C5 to determine if blockage or restriction is causing overheating
3)if 1&2 are good - check with pressure gage the condition of the system and integrity of the block and head gaskets
What about engine oil temps for the same two conditions?
Bill
Also 220-230 driving is knowhere near cool, thats more like the limit you want to see. I get about 190 driving 80 mph.
The fans should cycle on and off(ac off). Another indication that it may be a radiator is if it seems to run hotter when the car is working harder, pulling hills. The radiator has to displace the heat generated by the engine and if it's plugged up and not transfering the heat properly, it will run hot. :seeya
