Srevice Column Lock
Old Jul 25, 2003 | 08:45 PM
fairway's Avatar
fairway
Default Srevice Column Lock
Is there a trick to unlock the steering wheel I've done it before but I foregot how to get it unlocked.
Old Jul 25, 2003 | 08:53 PM
jmX's Avatar
jmX
Default Re: Srevice Column Lock (fairway)
Well, the computer sends an "unlock" pulse every time you turn the key to the on position (but not start the car)...
...so....constantly turn the key on, then off and remove the key (remember, dont start the car), and shake the steering wheel back and forth as hard as you can as you are turning the key on.
There's probably about 20 techniques for this, but the general idea is shake violently back and forth while turning the key.
..Then buy a bypass.
Jon
http://www.ls1howto.com
Old Jul 25, 2003 | 11:12 PM
fairway's Avatar
fairway
Default Re: Srevice Column Lock (jmX)
Thanks jmx I will try that.
Old Jul 26, 2003 | 12:02 AM
fairway's Avatar
fairway
Thanks jmx and Tuan Le for the help I got the steering wheel unlocked now its time for the column lock bypass.
:steering: :seeya
Old Jul 26, 2003 | 01:56 AM
Sales@MVPAutoParts.com's Avatar
0Sales@MVPAutoParts.com
Former Vendor
:steering: :seeya
Glad it worked. :thumbs: :cheers:
Old Jul 26, 2003 | 01:57 AM
DadsC5's Avatar
DadsC5
If I'm not mistaken there is a recall for the 98 and up for this. My dad's 97 wasn't covered so it cost him about 250 for a dealer fix.
Old Jul 26, 2003 | 08:12 AM
fairway's Avatar
fairway
Default Re: Srevice Column Lock (DadsC5)
Mine is a 97 too why not recall all C-5's?
Old Jul 26, 2003 | 09:28 AM
Radiant Heat's Avatar
Radiant Heat
Is the column lock still a problem on 2003's?
To Srevice Column Lock
