Rotors on the way which Pads?
Old Jul 25, 2003 | 09:45 PM
Jimmy O's Avatar
Jimmy O
Cruise-In IV Veteran
Default Rotors on the way which Pads?
My Eradispeed rotors are coming in a week.
Still not sure which pads?
Hawks or GM ceramic pads?
Any info about brake dust or sqeaking problems?
Thanks any info would help?
Jimmy O :smash:
Old Jul 25, 2003 | 09:55 PM
BillY2KFRC's Avatar
BillY2KFRC
Default Re: Rotors on the way which Pads? (Jimmy O)
I'd do the '02 Z06 pads. They are awesome, no noise, and stop far better than the regular C5 pads. They do dust a lot though. But I use them with my powerslot rotors and love how they stop.
Old Jul 25, 2003 | 11:02 PM
johnnyvettes's Avatar
johnnyvettes
CHICAGO CREW !
From: We are living in a Bazzaro World everything is upside down half ass backwards !
CI 4-5-6-7-8-9 Veteran
St. Jude Donor '06-'07-'08 & '12
Default Re: Rotors on the way which Pads? (BillY2KFRC)
http://temp.corvetteforum.net/c5/ken...rtspage2.shtml
jimmy on the bottom of the page z06 pads then you use standard c5s on the back :yesnod:
Old Jul 26, 2003 | 12:08 AM
VETFVER's Avatar
VETFVER
I'm happy with my Raybestos Quiet Stops! Here is what Raybestos says about this pad:
"The Quiet Stop line is neither semi-metallic nor NAO (non-asbestos organic), but a new friction blend made from ceramic ingredients instead of iron fibers and steel powders, which are found in semi-metallic pads.
These disc brake pads are 100 percent shimmed, slotted and chamfered to provide ultra quiet braking, low dusting, exceptional durability, resistance to fade and rapid recovery."
:yesnod:
Old Jul 26, 2003 | 01:05 AM
vetterdstr's Avatar
vetterdstr
CA Events Coordinator
If you are going to drive the car on the street... get the OE pads. They will work fine and your rotors will shine very nicely. Switching to high dust or carbon based pads will make your wheels and rotors look like hell... :eek:
vetterdstr :cheers:
Old Jul 26, 2003 | 05:15 AM
John Shiels's Avatar
John Shiels
From: Buy USA products! Check the label! Employ Americans
Default Re: Rotors on the way which Pads? (vetterdstr)
vetterdstr :cheers:
:iagree:
I used Raybesto's on the street lighty and the pads seperated fron the backing plate. There performance is nothing great either
Old Jul 26, 2003 | 03:28 PM
SFVetteman's Avatar
SFVetteman
Default Re: Rotors on the way which Pads? (John Shiels)
I use ceramic pads. Their performance is about equal to the original pads but they don't produce the visable dust that the originals did. I say visable because you don't notice the dust on the wheel unless you wipe it with your finger and then your finger turns black.
Old Jul 27, 2003 | 12:31 AM
TNTC5's Avatar
TNTC5
Call Lou at LG for new Wilwood pads, they are great with my new bare set up
BTW: you have to do bedding & seasoning process inorder to work great.
[Modified by TNTC5, 11:33 PM 7/26/2003]
Old Jul 28, 2003 | 08:53 PM
johnnyvettes
CHICAGO CREW !
:crazy:
Old Jul 29, 2003 | 03:55 PM
johnnyvettes
CHICAGO CREW !
no one :confused: :confused: :confused: :confused:
Old Jul 29, 2003 | 04:38 PM
bandit_99's Avatar
bandit_99
Jimmy-
I've got GM ceramics on all four corners. Dust is much less visable than the dust from the stock pads and IMO, they seem to provide the same stopping power. If you stay on the streets, I'd recommend them. But I don't have the extra power of a Supercharger either. :D
Old Jul 29, 2003 | 04:41 PM
Smoke-N-Shot's Avatar
Smoke-N-Shot
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In VI Veteran
Hawk Street Pads... They are great and I get minimal dust! :steering:
To Rotors on the way which Pads?
