Will Underdrive pullies help idle on Fat cam?
Old Jul 26, 2003 | 09:00 PM
Noran Raad's Avatar
Noran Raad
St. Jude Donor '08
Default Will Underdrive pullies help idle on Fat cam?
Hey all... Just got my 98 A4 back -- ported Ls6 heads w/MMS V2.1 (229 .578" 114LS) cam. Tuning was apparently a nightmare (had to set idle at 1000rpms) & it cuts off at most traffic lights. I've been told driving will allow it to re-learn & hopefully improve in time. Does anyone have suggestions i.e. underdrive pullies, injectors, ignition, smaller cam (.224...
PS -- I keep it running at the light by turning on the ac. :nopity
Old Jul 26, 2003 | 09:15 PM
vetterdstr's Avatar
vetterdstr
CA Events Coordinator
Default Re: Will Underdrive pullies help idle on Fat cam? (Noran Raad)
I dont think that the underdrive pulley is going to help that situation... sound like you need some more tuning with LS1 edit. :yesnod: Is there anyone in your area that can do it for you??
vetterdstr :cheers:
Old Jul 26, 2003 | 09:16 PM
Brian@KelleyPerf's Avatar
Brian@KelleyPerf
Noran, which shop did your tuning???
[Modified by Brian@KelleyPerf, 9:17 PM 7/26/2003]
Old Jul 26, 2003 | 09:20 PM
IT L GO's Avatar
IT L GO
Who did your install and your LS1 edit?
I live in the area also and I'm looking for a tuner :chevy
[Modified by IT L GO, 9:21 PM 7/26/2003]
Old Jul 26, 2003 | 09:33 PM
Patches's Avatar
Patches
I'm running basically the same MMS cam except on the tougher 112 LSA and have no problem idling at 900 with the proper tuning. Get someone who knows what they're doing to tune it for you. :cheers:
Old Jul 26, 2003 | 10:08 PM
Brian@KelleyPerf
Default Re: Will Underdrive pullies help idle on Fat cam? (IT L GO)
[QUOTE]Who did your install and your LS1 edit?
Come by and see us soon.. We have a brand new Dynojet 248 with a Wideband 02 and use LS1 edit to tune!!
Old Jul 27, 2003 | 08:44 AM
Noran Raad's Avatar
Noran Raad
St. Jude Donor '08
Default Re: Will Underdrive pullies help idle on Fat cam? (Brian@KelleyPerf)
I thought it would be tuning issue. I take my car to Breathless who has done a stellar job on my car since I've had it. The cylinder heads had some compatiablity issues but I think the problem is the cam. The car was not tuned on the dyno however which may be the issue. It is work in progress & the recommendation was to drive it for a while & later follow up. Breathless is located in Dania 30 minutes from me.
Old Jul 27, 2003 | 09:05 AM
MiamiDave's Avatar
MiamiDave
A4's are harder to tune with big cams but Brian at KPD is very competent in tuning big cams. He's got a lot of LS1 tuning experience and has that beautiful dyno to really map out the car :thumbs:
Old Jul 27, 2003 | 09:14 AM
GaryZ06's Avatar
GaryZ06
Brian at Kelley Performance is your man to cure your woes.He is a master at LS1 Edit. :steering:
Old Jul 27, 2003 | 02:39 PM
RWhite's Avatar
RWhite
Default Re: Will Underdrive pullies help idle on Fat cam? (GaryZ06)
Should be easy to tune that cam with LS1Edit and someone who knows what he is doing (especially with an A4 car). That is the key!
Old Jul 27, 2003 | 03:52 PM
Mitch C's Avatar
Mitch C
Default Re: Will Underdrive pullies help idle on Fat cam? (RWhite)
:iagree:
Old Jul 30, 2003 | 10:26 PM
Brian@KelleyPerf
Default Re: Will Underdrive pullies help idle on Fat cam? (Mitch C)
It was a pleasure to meet you today Pete and hope that you are happy with your car now!!! You should notice that your car should idle a lot smoother now and have some more power from idle to redline.
Your A4 really is running very well now!!!
Thanks for the business!!!
Old Jul 30, 2003 | 11:08 PM
Z06TheKid's Avatar
Z06TheKid
Another satisfied Kelley Chevrolet Performance customer :cheers:
To Will Underdrive pullies help idle on Fat cam?
