Charging System Fault on DIC
Old Jul 27, 2003 | 11:06 PM
hokievette03's Avatar
hokievette03
St. Jude Donor '05-'06
Default Charging System Fault on DIC
Has anyone else seen this 'Charging System Fault', happened a few weeks ago, by the time the dealer got a Tech II on it they couldn't find anything, haven't seen it since, know it has to do with the 12V charging system [from the service manual] but beyond that I am in the dark...
Old Jul 27, 2003 | 11:45 PM
Rookiedyn's Avatar
Rookiedyn
Default Re: Charging System Fault on DIC (hokievette03)
I read a ton of threads in regards to this in the archives when I received the same notice on my DIC and it didn't appear that anyone had a definitive answer. From what I gathered as long as there wasn't any further problems it may just be a temporary "glitch". I am sure someone else will chime in with there experience.
Old Jul 28, 2003 | 12:09 AM
mapman's Avatar
mapman
Any DTC codes set?
Old Jul 28, 2003 | 12:14 AM
Tony @ MPH's Avatar
Tony @ MPH
Supporting Vendor
I received a Charging System Fault DIC message when my alternator died... Could your alternator be on the edge of death?
Old Jul 28, 2003 | 12:31 AM
mapman's Avatar
mapman
Any DTC codes set? Any data in Fail Records"?
Old Jul 28, 2003 | 04:48 PM
Civil Man's Avatar
Civil Man
I have a 2002 Z06 with 2500 miles. I started the car this weekend and noticed this on my DIC as well. I am going to go home and start the car again to see if it happens again. I thought the display was part of the start up process. Now I am worried. :rolleyes:
Old Jul 28, 2003 | 04:52 PM
BlkThunder's Avatar
BlkThunder
Default Re: Charging System Fault on DIC (Civil Man)
I had this happend last week, it showed up once, and hasn't shown up again. One person said it might have been because I had my radio on and my A/C blasting. It hasn't happened since, and my car is not running hot. So who knows :rolleyes:
Old Jul 28, 2003 | 05:29 PM
NEPTUNEBILL's Avatar
NEPTUNEBILL
Default Re: Charging System Fault on DIC (BlkThunder)
I'm waiting on an alternator that will be here in the morning as we speak, the damn thing went nuts as I was leaving the house the other night fortunately I made it back to my driveway, I will let you know when I swap them out if this is the problem but I did get the same message and the amp gauge was headed for zero and not charging at all.
Old Jul 28, 2003 | 11:18 PM
SHOWTIME!'s Avatar
SHOWTIME!
Default Re: Charging System Fault on DIC (NEPTUNEBILL)
:lurk:
Old Jul 29, 2003 | 12:27 AM
philthy's Avatar
philthy
From: Land of the heartless the home of the paid. Miami FL
Default Re: Charging System Fault on DIC (SHOWTIME!)
WOW I just had this happen yesterday same .scenario Everything looks fine the voltage gage. Thats weird it's happening to so many at the same time.
Old Jul 29, 2003 | 02:03 AM
molon labe's Avatar
molon labe
it happens occasionally on my c5 when i have the stereo cranked (1100 watt aftermarket system), have thge piaas on, and have the AC and headlights on. i've got a stock alternator, big cap for the stereo, and a yellow top battery. a better alternator would probably solve my problem - maybe i'll get around to installing one some day soon. :)
Old Jul 29, 2003 | 08:36 AM
Civil Man's Avatar
Civil Man
I went home and started the vette up last night. Nothing on the DIC except the odometer reading :cool:
I will keep an eye out for this in the future.
Old Jul 29, 2003 | 10:37 AM
Cybercowboy's Avatar
Cybercowboy
From: Blacker than the blackest black, times infinity.
Stealthy Puma Member
Cruise-In IV Veteran
This has happened to me twice on my 02 C5 vert. Both times were in May, a year apart. I was wondering if it was somehow weather-related because of that. Anyway I've had no problems associated with my charging system and no other DIC messages related to this or anything else for that matter.
When it first happened last year I created a thread similar to this one and the concensus was then that it is rather common and as long as it is very infrequent you are OK.
Old Jul 29, 2003 | 03:49 PM
jr cumberbatch's Avatar
jr cumberbatch
Cruising
Funny,this just happened to my 01 coupe.After filling up with petrol i started the car and it died twice.Then i saw the 'charging system fault' on the DIC.The car started on the third try and everything was normal ever since.I did have my stereo and a/c on while starting the car though. Hopefully its not a sign of problems to come.
Old Aug 10, 2003 | 12:06 AM
hokievette03
Default Re: Charging System Fault on DIC (jr cumberbatch)
Thanks for all the replies. I took it to the dealer no codes no nothing. Looks like it is just an occasional occurence, hasn't happened since I originally posted...
Old Aug 10, 2003 | 12:38 AM
torchredvette99's Avatar
torchredvette99
I've had my 99 since 98 and have seen this alarm several times in five years. It bugged me at first but if it happens I check the voltage, hit reset and go on my way. Voltage is always around 14V but when this happens who knows how low the voltage gets. I also have three aftermarket amps and a "spare battery" in the back of the car for the current those amplifiers draw on a stock alternator. Could be part of the problem :lolg:
Old Aug 10, 2003 | 01:59 AM
RussBt's Avatar
RussBt
From: Admit Nothing, Deny Everything, Make Counter Accusations.
Default Re: Charging System Fault on DIC (torchredvette99)
I see this every once in a while while first starting my car after it sits for over a week. I clear the message and I do not see it again until the car sits unused for over a week.
To Charging System Fault on DIC
Old Aug 10, 2003 | 02:12 AM
SleepieAce's Avatar
SleepieAce
From: Kentucky basketball is life the rest is just details
Default Re: Charging System Fault on DIC (rbartick)
Saw it once, a couple of weeks ago right after start up. It went away and hasn't come back :thumbs:
Old Aug 10, 2003 | 01:40 PM
MagRedRuss's Avatar
MagRedRuss
I had this "Charging Fault" pop up a few times on the DIC, so I took the car to the dealer. They found a cracked terminal on the starter and replaced the starter.
Russ
Old Aug 10, 2003 | 08:46 PM
RedC5's Avatar
RedC5
Default Re: Charging System Fault on DIC (MagRedRuss)
I just got this fault when I changed batteries to a Red Top after I started it? Why?? :confused:
