FOG LAMPS
Old Jul 28, 2003 | 09:47 AM
David-F's Avatar
David-F
Default FOG LAMPS
DOES ANYONE KNOW IF FACTOR FOG LAMPS CAN BE PUT IN A CAR THAT DOESN'T HAVE THEM. i.e. ARE THE CONECTOR FOR THE FOG LAMPS ALREADY WIRED IN? I KNOW THE FUSE AND RELAY IS ALREADY THERE AND THE WIRING AT THE SWITCH? THANKS
Old Jul 28, 2003 | 12:26 PM
Special K's Avatar
Special K
Default Re: FOG LAMPS (David-F)
:lurk:
Old Jul 28, 2003 | 01:33 PM
NavyC5's Avatar
NavyC5
CI 3-4-5-6-10 Veteran
St. Jude Donor '03-'06-'08-'09-'10
Default Re: FOG LAMPS (Korreck)
I'm pretty sure they can be. The wiring harness should be setup for them. I'm not sure about the connection in the dash, but I do believe it is there. :yesnod:
Old Jul 28, 2003 | 01:39 PM
Kal-El's Avatar
Kal-El
Mine came with fogs but I have replaced them with PIAA and absolutely love them. Here is a link to tech tips that discusses putting fogs on a Z06.
https://www.corvetteforum.com/techti...=130&TopicID=1
Old Jul 28, 2003 | 01:57 PM
paid4c4's Avatar
paid4c4
Default Re: FOG LAMPS (Kal-El)
I changed mine to the PIAA's which can be added to any C5 without a lot of problem, they look good and drive great!!!! Check TUAN here on CF for group pricing on the PIAA's. Good Luck with your project.
Bill :) :)
Old Jul 29, 2003 | 01:35 AM
Sales@MVPAutoParts.com's Avatar
0Sales@MVPAutoParts.com
Former Vendor
Default Re: FOG LAMPS (paid4c4)
Thanks for the referral, Bill. I appreciate it :)
Here is the link to order the PIAA 1100X if anyone is interested. :cheers: http://www.tlelectronics.com/webstor...roducts_id=149
Old Jul 29, 2003 | 03:23 AM
Z06-JIM's Avatar
Z06-JIM
Cruise-In VII Veteran
Default Re: FOG LAMPS (Tuan Le)
I installed them on my Z06 and would highly recommend them! Easy install, all I had to buy extra was a combination trunk/fog light switch. The wiring harness was already there in the dash. These lights are awesome, I use them most of the time instead of my head lights.
:steering:
To FOG LAMPS
