headers burn plug wires?
Old Jul 28, 2003 | 04:36 PM
C7GrandSport's Avatar
C7GrandSport
Default headers burn plug wires?
Do I need to insulate my spark plug wires to run FLP long tube headers?
Opinions and experience please...
Old Jul 28, 2003 | 04:39 PM
DS's Avatar
DS
Default Re: headers burn plug wires? (c5grandsport)
you can, but I don't think you will need them. If you have aftermarket wires, just cut them to have very little slack. They should only burn thrm if they touch.
Old Jul 28, 2003 | 05:48 PM
jawski's Avatar
jawski
Default Re: headers burn plug wires? (DS)
i'm using the stock heat shields...no problems.....yet.
Old Jul 28, 2003 | 05:50 PM
cfi_luz's Avatar
cfi_luz
Default Re: headers burn plug wires? (jawski)
I was wondering the same thing, but I think when I install my headers I'll just get a set of the spark plug boots as cheap insurance (around 50.00).
Old Jul 28, 2003 | 06:20 PM
Smoke-N-Shot's Avatar
Smoke-N-Shot
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In VI Veteran
You can get heat socks to put over your wires and that will solve your problem...
Old Jul 28, 2003 | 06:46 PM
Tony @ MPH's Avatar
Tony @ MPH
Supporting Vendor
When my SLP LT Headers were installed, the AC line was a little too close. After a few days of abuse, the headers completely melted through the line (which is metal, I believe) and soon Corvette was spewing a lovely white smoke with an interesting burning refrigerant aroma.
So yes... your headers could burn through plug wires and other things if they are too close, too long, in too hot of weather.
Old Jul 29, 2003 | 11:39 AM
99C5JA1's Avatar
99C5JA1
Default Re: headers burn plug wires? (diynoob)
Just burned through one of my GM high performance wires this last weekend. Thank god I was taking the car to be tuned and the tuner had a spare for me. Installed the sotck heat boots from the old wires and ordered a new set. This is with the FLP's.
Old Jul 29, 2003 | 12:55 PM
Buckmaster's Avatar
Buckmaster
Cruise-In V Veteran
St. Jude Donor '03-'04
Default Re: headers burn plug wires? (Smoke-N-Shot)
:iagree: thunderracing.com No problems here.
Old Jul 29, 2003 | 01:54 PM
MTWallet's Avatar
MTWallet
Default Re: headers burn plug wires? (Buckmaster)
I am using Taylor wires and they fit perfect and sit away from the pipes on my FLP's.
Old Jul 29, 2003 | 03:57 PM
MiamiDave's Avatar
MiamiDave
Default Re: headers burn plug wires? (MTWallet)
FLP's will generally burn stock wires. Z06TheKid just fried his number 7 plug within days of an FLP instalation.
I have the FLP's also. Go with MSD's (better boot design) and Thunder Racing Cool Sox. I've had mine on for almost a year and 7,000 miles with no problems whatsoever-and it get's hot down here :mad
Old Jul 29, 2003 | 09:35 PM
alc2001's Avatar
alc2001
I have Taylor Thundervolt 10.4 wires. Clearance was too tight so I installed fire sleeve boot protectors too. No problems after 7k miles.
:seeya
Old Jul 29, 2003 | 09:39 PM
Z06TheKid's Avatar
Z06TheKid
Default Re: headers burn plug wires? (MiamiDave)
:iagree:
Old Jul 29, 2003 | 09:56 PM
BlueDragon's Avatar
BlueDragon
Default Re: headers burn plug wires? (Z06TheKid)
HUM, I have 70K on my headers, and if the fit is right you should not burn any wires. I have the MSD on now and they are great. Eventually the heat will break them down, but you should get at least 50K miles out of them. I had the Taylors, but they were to loose, so I went back to the stock wires for a while.
Jer
Old Jul 29, 2003 | 10:16 PM
Z06TheKid's Avatar
Z06TheKid
Default Re: headers burn plug wires? (BlueDragon)
My stock plugs only lasted a few days until the number 7 wire bit the dust. I have the MSD wires on now and hopefully these will last a long time.
Old Jul 29, 2003 | 10:36 PM
MTWallet's Avatar
MTWallet
I haven't tried or seen the Taylor Thundervolts but mine are the Taylor SpriroPro. They have about 3/16" clearance on #7 cylinder and even more on the others. Noo need for socks here!
Old Jul 29, 2003 | 10:40 PM
C7GrandSport
Thanks to all. Bought a set of Taylor plug socks today for 40 bucks. An ounce of prevention...
Old Jul 30, 2003 | 07:30 PM
boost2much's Avatar
boost2much
I burnt my stock plug wires even with the heat shields on it since it was touching the headers. Changed to MSD wires and its alot better since it doesn't touch the headers.
To headers burn plug wires?
