Re-route the clutch bleeder?
Old Jul 30, 2003 | 10:14 AM
'97 C5's Avatar
'97 C5
Default Re-route the clutch bleeder?
Has anyone re-routed or in any way modified the slave so that the bleeder is more accessible?
Old Jul 30, 2003 | 10:21 AM
C5-VERT's Avatar
C5-VERT
Cruise-In IV Veteran
Default Re: Re-route the clutch bleeder? ('97 C5)
I thought about doing that. It would not be that hard. Just get some SS braided high pressure line threaded in to one end and put a bleed valve on the other end. Not much to it.
Old Jul 30, 2003 | 03:26 PM
'97 C5's Avatar
'97 C5
Default Re: Re-route the clutch bleeder? (C5-VERT)
That's my thoughts...hoping someone already did this and has links to the various parts and adaptors..if not I'll run all the stuff down myself
Old Jul 31, 2003 | 01:43 PM
HurricaneZ's Avatar
HurricaneZ
Make sure you post the findings :thumbs: :thumbs:
Old Jul 31, 2003 | 10:29 PM
Stock Man's Avatar
Stock Man
2015 C5 of Year Finalist
St. Jude Donor '05-'06-'07-'08-'09-'10
Default Re: Re-route the clutch bleeder? (HurricaneZ)
I am about to do mine and have heard that it can get pretty messy so I'll be waiting for a reply. But if you extend the line doesn't it make the area that is being pressurized larger and in doing that the clutch may not operate properly. Just a thought! I am probably all wet.
Old Jul 31, 2003 | 11:43 PM
alc2001's Avatar
alc2001
Roxana,
There have been several previous threads on the subject of adding a flexible bleeder line to the slave cylinder. I recall that the concensus was that it could be done but only if you had the cylinder removed from the car. There's no room to get at it otherwise. I have wondered whether it might be possible to pull back the carpet and punch a hole in the floorboard to get at the bleeder. I have not heard of this being done, though. If you discover any simpler approach, please share.
Alan :seeya
Old Aug 1, 2003 | 01:11 AM
C5-VERT's Avatar
C5-VERT
Default Re: Re-route the clutch bleeder? (alc2001)
I know it can definately be done. The bleed bold just threads into the slave now. I pulled it apart and it would not be hard to do. Adding the length of SS braided line would not effect the clutch play at all.
To Re-route the clutch bleeder?
