315 Gear Install?
Old Jul 30, 2003 | 12:36 PM
Vegas Vette's Avatar
Vegas Vette
Default 315 Gear Install?
can anyone tell me if a 315 gear will fit in a 273 carrier with out machineing it?. :chevy
Old Jul 30, 2003 | 01:16 PM
Mike Mercury's Avatar
Mike Mercury
Default Re: 315 Gear Install? (razor2430)
no
Old Jul 30, 2003 | 02:06 PM
Vegas Vette
Default Re: 315 Gear Install? (Mike Mercury)
Thanks for the info..I guess I need a whole Diff!! :cheers:
Old Jul 30, 2003 | 02:21 PM
Redvette_22's Avatar
Redvette_22
Yes it will, if you use the "new" special parts made available
Old Jul 30, 2003 | 04:38 PM
Mike Mercury
Default Re: 315 Gear Install? (Red98C5)
from 2.73 to any other C5 ratio... you'll need to reprog (there's no way to get around it); so you moght as well get a 3.42 carrier.
Old Jul 30, 2003 | 05:47 PM
Special K's Avatar
Special K
:iagree:
Been there, done that.
Bob
:flag
Old Jul 30, 2003 | 06:30 PM
Vegas Vette
Default Re: 315 Gear Install? (Korreck)
can you guys enlighten me on this issue. So what you are saying is that you can put a 315,342 ect in a stock 273 carrier without machinening the carrier to fit the new gears with some special part? Is from GM or some other vender? And what do you have to do to reprogram the onbaord computer? And how does this part work? You can E-Mail me with details.
Thanks :thumbs:
Old Jul 31, 2003 | 12:53 PM
Vegas Vette
TTT.. :confused:
Old Jul 31, 2003 | 01:07 PM
Redvette_22
You must reprogram the PCM for shift points when replacing the 2.73 or 3.15 gears, and the best way is with LS-1 Edit. If however, you already have a Hypertech or other unit like it, you can "fool" the PCM into accepting the replaced gears, within limits that is.
The part to put the 3.15 or numerically higher gears in is not made by GM....but is available.
Old Jul 31, 2003 | 06:47 PM
Mike Mercury
are these "special parts" available seperately... or must you send the entire pumpkin out?
And you mean to say that no internal machining or grinding is required with the 2.73 case upgrade?
[Modified by Mike Mercury, 6:48 PM 7/31/2003]
To 315 Gear Install?
