Head and Cam install, any tip for power steering bracket?
Old Jul 30, 2003 | 12:59 PM
Phil97SVT's Avatar
Phil97SVT
Default Head and Cam install, any tip for power steering bracket?
Are there any ways to make installation of the idler pulley/power steering fluid canister easier? This bracket has 4 bolts, 2 are easy to get to and 2 are a PITA. I was thinking that removing the idler pulley would make this easy. Anyone have any tips?
Phillip :cheers:
Old Jul 30, 2003 | 01:27 PM
fuel524's Avatar
fuel524
Default Re: Head and Cam install, any tip for power steering bracket? (Phil97SVT)
I would like to know too :lurk: Maybe jmX knows and will chime in, his site is awesome :thumbs:
Old Jul 30, 2003 | 03:25 PM
SpinMonster's Avatar
SpinMonster
witht the water pump off they are easy to get to. ????
Old Jul 30, 2003 | 07:51 PM
1SlowC5's Avatar
1SlowC5
If I remember right I used a rachet wrench (boxed end of wrench ratchets) to get those two pita bolts. :cheers:
Old Jul 30, 2003 | 07:53 PM
Phil97SVT's Avatar
Phil97SVT
Default Re: Head and Cam install, any tip for power steering bracket? (1SlowC5)
Can you remove the idler pulley?
Phillip
Old Jul 30, 2003 | 10:36 PM
Chris@East Coast Supercharging's Avatar
Premium Supporting Vendor
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In V Veteran
I usually remove the waterpump first so you can reach the outside one and I also remove the resovoir itself. Just get a turkey baster and take the fluid out and once thats out of the way you can get the the bolts pretty easily.. Call if you have any more questions. :seeya
Old Jul 30, 2003 | 10:45 PM
Patches's Avatar
Patches
Default Re: Head and Cam install, any tip for power steering bracket? (CHRIS NJ C5)
:iagree: With the water pump out of the way, it's no problem.
To Head and Cam install, any tip for power steering bracket?
