Cylinder head gaskets....
Old Jul 30, 2003 | 03:43 PM
Phil97SVT's Avatar
Phil97SVT
Default Cylinder head gaskets....
Are there any differences between all of the gaskets on the market?
GM
Fel pro
Cometic
Victor Reinz
Old Jul 30, 2003 | 10:37 PM
Chris@East Coast Supercharging's Avatar
Premium Supporting Vendor
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In V Veteran
Default Re: Cylinder head gaskets.... (Phil97SVT)
I have had good luck so far with the Cometics. :seeya
Old Jul 30, 2003 | 10:43 PM
Patches's Avatar
Patches
I see you have the 5.3 L heads. I'm currently using the stock pre-'01 gaskets because of my experience with the Cometics and also because of the "notch" in my heads. Here's a post I documented the problem in.
http://forums.corvetteforum.com/zerothread?id=489800
Old Jul 31, 2003 | 10:35 AM
SpinMonster's Avatar
SpinMonster
Default Re: Cylinder head gaskets.... (Patches)
Hey Ed when you ordered the cometics did you specify the 5.3L heads or did you order gaskets for a LS1 saying the car was a corvette? If you ordered the stock corvette LS1 gaskets, you ordered the wrong ones. If you said you had the truck that those heads come stock on would have gotten the same model? I asked for LS6 gaskets since my engine and block are both 2002 LS6 although the car is a 2001 c5. They sell over 20 different models for Chevy ls1/ls6 blocks in any thickness.
Old Jul 31, 2003 | 11:29 AM
Patches's Avatar
Patches
Default Re: Cylinder head gaskets.... (SpinMonster)
Actually, SpinMonster I ordered the Cometics from Mike Morgan of MMS at the same time I ordered the heads he was porting for me. Actually, Mike was the one who suggested and then specified those Cometics. He uses them quite a bit himself.
Note that my driver side had no problem at all from day one. The leak was very small and, had the casting been just a few thousandths larger, there would have been no problem.
To Cylinder head gaskets....
