Not so smooth.
Old Jul 30, 2003 | 05:24 PM
cat_gzz's Avatar
cat_gzz
Default Not so smooth.
My car is not shifting smoothly from park to reverse, and from 1st to 2nd. It is an Auto. When I put my car in reverse, it jerks real bad; same thing happens from 1st to 2nd.
The car has 62k on it.
Is it time for a tranny oil/filter change?
What can be causing this?
Any suggestions are greatly appreciated.
Thanks in advance,
cat..
Old Jul 30, 2003 | 08:13 PM
mapman's Avatar
mapman
Default Re: Not so smooth. (cat_gzz)
Any DTC fault codes?
A/T fluid change suggested at 50,000 miles when in heavy trafffic where outside temperature regularly reaches 90F or higher, or if driven in hilly or mountainous terrain, or Used in high performance operation.
In other words a fluid change wouldn't hurt.
Have you had any A/T fluid temperature warnings? Any transmission leaks? What is the condition of the A/T fluid, appearance, smell, contaminants,etc?
Has any "tuning" been done that effects transmission line pressure?
Has the PCM been replaced or any repair or adjustment to a component that directly affects line pressure? The items above can cause the Transmission Adaptive Pressure (TAP) to be reset. If so that information has to be relearned by the Powertrain Control Module (PCM), shifting performance is effected during the relearning time.
A scan tool can check on the TAP values to determine if the transmission has adjusted line pressure correctly.
Several other electrical and mechanical faults could give you this problem. You might check the service manual.
Old Jul 31, 2003 | 02:01 PM
cat_gzz's Avatar
cat_gzz
Default Re: Not so smooth. (mapman)
Thanks for the info. I will check the fluid and try to get the codes. I'll post them.
To Not so smooth.
