Shifter Too Notchy....
Old Jul 31, 2003 | 03:42 PM
tlaselva's Avatar
tlaselva
Default Shifter Too Notchy.... Help!
My '03 Z06 shifter's way to notchy.
Too notchy infact that I consistantly miss shifts when I'm at the strip. :mad
In contrast, a friend of mine with a '00 FRC's shifter is so smooth, I feel I could blow the shifter into it's gear!
Is there a way to smooth out the shifter somewhat?
Thanks All!
[Modified by tlaselva, 3:43 PM 7/31/2003]
Old Jul 31, 2003 | 04:03 PM
Elk's Avatar
Elk
Default Re: Shifter Too Notchy.... Help! (tlaselva)
Two suggestions:
1) a good synthetic tranny fluid; Amsoil ATF, Redline D4ATF, Royal Purple, etc.your choice. This will help smooth out the transmission.
2) I think shifts are missed because of the rubber isolation bushing in the stok shifter. Either modify that stock shifter (search for info on the forum, the topic keeps coming up) or buy a B&M, Hurst, etc. I don't drag race and found the B&M return springs too stiff for road track work, but I understand that many drag racers love it.
Good luck!
Old Jul 31, 2003 | 06:26 PM
Bugster57's Avatar
Bugster57
Mileage, the older cars tranny probably has just loosened up a bit. Just drive yours and it'll get smoother. Both of mine have.
Old Jul 31, 2003 | 08:11 PM
allanlaw's Avatar
allanlaw
You have a Hurst shifter, and I'll guess your friend has a stock shifter. The stock shifter has a rubber arrangement in the shifter shaft that smooths out the FEEL of the movement from one gear to the next, whereas the Hurst lets you feel exactly what is happening in the linkage. The C5 linkage is inherently notchy. So, if you want smoothness, go back to the stock shifter. If not, stick with the Hurst, and just learn to to work with the side to side spring load to avoid missed shifts (your T-handle makes it easier to miss gears). The Ripper and the BPP short shifters feel the same as the Hurst with respect to notchiness.
[Modified by allanlaw, 5:12 PM 7/31/2003]
Old Jul 31, 2003 | 08:42 PM
CR555's Avatar
CR555
Default Re: Shifter Too Notchy.... Help! (allanlaw)
Go with the Mallett shifter, and you'll have best of both worlds. :smash:
Old Jul 31, 2003 | 09:37 PM
allanlaw's Avatar
allanlaw
Default Re: Shifter Too Notchy.... Help! (CR555)
One would hope so, for $450 :eek:
Old Jul 31, 2003 | 09:41 PM
Oldvetter's Avatar
Oldvetter
Z06s have different sychronizers than C5s, steel verses (bronze ?) They will be notcher.
Old Jul 31, 2003 | 09:47 PM
fast2000vette's Avatar
fast2000vette
Default Re: Shifter Too Notchy.... Help! (Oldvetter)
I keep missing 3rd in my 00 FRC. I just ordered a hurst shifter hoping this fixes the problem, I hated the feel of the shift from day one. Also a trans fuid C/O is coming.
:seeya
Old Aug 1, 2003 | 06:01 AM
CR555's Avatar
CR555
You can get the Mallett for $375 if you send your stock shifter in. :cheers:
http://forums.corvetteforum.com/zerothread?id=613530
Old Aug 1, 2003 | 06:40 AM
adame780's Avatar
adame780
I installed a B&M Ripper and it helped some and my next step is to change the fluid to redline.
[Modified by adame780, 11:40 AM 8/1/2003]
To Shifter Too Notchy....
