18's all around question
Old Aug 1, 2003 | 10:03 PM
99LS1FUN's Avatar
99LS1FUN
Default 18's all around question
Does anything need to be done in terms of reseting the computer when I go to all 18's. :confused:
Old Aug 1, 2003 | 10:10 PM
robsvette's Avatar
robsvette
Default Re: 18's all around question (99LS1FUN)
NOPE nothing at all, but just slapping them on
AC54ME's Avatar
AC54ME
CI 6-7-8-9 Veteran
CI-VI Car Show Winner
St. Jude Donor '07-'08-'09-'10-'11-'12-'13
Nope.
Old Aug 2, 2003 | 08:10 PM
dads01dream's Avatar
dads01dream
Default Re: 18's all around question (AC54ME)
Would there be any problem putting 275's x 18 at all 4 corners? That way we could rotate the tires??? Just curious.
Old Aug 2, 2003 | 09:44 PM
jschindler's Avatar
jschindler
Default Re: 18's all around question (dads01dream)
Yes, big problem. You would wind up with front tires one inch taller than stock. Wouldn't look right, would probably rub, and might create problems with ABS, active handle etc.
Old Aug 3, 2003 | 11:32 AM
mapman's Avatar
mapman
This recent thread may be useful.
http://forums.corvetteforum.com/zerothread?id=617051
The computers need to see the same tire speed differential as stock for proper operation of ABS, Traction Control, etc.
In any case, rotating some tires could be dangerous. The Goodyear EMT tires, for example, have rotation arrows for the tire's direction. Normal side-to-side tire rotation would have these tires rotating the wrong way, a potentially dangerous situation.
Old Aug 3, 2003 | 02:51 PM
dads01dream
Default Re: 18's all around question (mapman)
Hey Mapman,
Thanks for the thread referral! :cheers: I have a Predator programmer that allows you to program in tire size changes, wonder if it will work? Though it appears the EBTCM "may" be an issue.
Anyways thanks again!
To 18's all around question
