Need help, air/fuel way lean
The only time I have ever seen such a lean ratio is when at part throttle and even then it is closer to 14.8-15.0 and usually never leaner.
Tell us more about the car. What mods have been done to it. Did you ever have your PCM tuned before?
You mentioned you had a K&N filter. Did you recently oil it? As you said, it is possible that some oil has gotten on the MAF sensor wires. If this is all that you have done, I would take off the MAF and CAREFULLY clean them with some q-tips and some alcohol. VERY Gently wipe them down with the q-tip turning it towards the clean side often. Discard the q-tip and use another one on all of the wire sensors.
Let us know how everything turns out..
Thanks for the boost of confedence :rolleyes:
1: Clean your MAF sensor wires as indicated in the previous post.
2: Change out fuel filter
3: Confirm that there are no intake leaks present. Check especially around where your K&N filter connects to your MAF and from the air bridge to the throttle body.
4: MOST IMPORTANT!! Go somewhere that has either an autotap tool or similar device or a Tech2 scan tool. This way you can see what is going on in your engine. For example, where are your LTFT settings at given fuel cells? What kind of timing and or KR are you getting?? These are things that can only be answered by using a scan tool connected to your vehicle.
The A/F ratios that you are currently running is a recipe for disaster. Seriously, get this fixed ASAP!! The computer is smart enough to lower your timing advance through KR but it only goes so far. The other post about the engine going boom is not so far off... Especially at WOT under severe knock..
Let us know how you do and if you need any further help...
