just lowered c5 how long till alignment
Old Aug 3, 2003 | 06:24 PM
shawn huether's Avatar
shawn huether
Default just lowered c5 how long till alignment
i just lowered my 98 with the stock bolts in front screwed all the way up, and in back i cut the bushing down to one with 2 threads left out on bolt. now how long can i drive the car with out hurting my new tires. or how long should i wait to get the car to the body shop to get it lined up? like how many miles?? thanks for any help!! :confused
Old Aug 3, 2003 | 06:30 PM
MeatheadsC5's Avatar
MeatheadsC5
Default Re: just lowered c5 how long till alignment (shawn huether)
Well I think its really only to wear out your tires a littl funny, and over a long period of time, maybe other susp. components, but the main reason not to wait is the feel after you get it aligned. World of difference.
Old Aug 3, 2003 | 06:35 PM
USARMYTTT's Avatar
USARMYTTT
First let me say, I just put on my flame suit!!!! I lowered mine on stock bolts about 9 month's ago and DID NOT do an alignment. I have put about 8,000 miles on since and tires are wearing fine, car tracks strait so..... I don't know. Some say do it, some say don't. I have checked around my area and have not found anyone I would trust to do it yet. So you decide, and I am sure you will get many opinions on this.
Old Aug 3, 2003 | 10:46 PM
Sixguns's Avatar
Sixguns
Default Re: just lowered c5 how long till alignment (USARMYTTT)
Same here, no alignment, no problems.
Old Aug 3, 2003 | 10:50 PM
anniv88's Avatar
anniv88
I lowered my 01 in the rear on the stock bolts. I went to have the
alignment checked and it was out. :eek:
Old Aug 3, 2003 | 11:02 PM
Stingray1967's Avatar
Stingray1967
Default Re: just lowered c5 how long till alignment (anniv88)
I lowered my stock suspension '00 coupe, and then drove it for 500 miles before I aligned it. Don't wait that long.
I just put on a new set of Firehawks because the GY's were BALD on the inside tread blocks.
I'd only wait 50 miles or so.
Old Aug 3, 2003 | 11:22 PM
MikeyD's Avatar
MikeyD
Maybe it was way out of alignment before you lowered :confused: I know some of the C5's were way out of wack right off the assembly line. Mine was. I heard they only check one out of so many coming off the line.
Old Aug 3, 2003 | 11:35 PM
Racer's Avatar
Cruise-In III Veteran
St. Jude Donor '11
Default Re: just lowered c5 how long till alignment (MikeyD)
two of my previous Vettes I lowered with the stock bolts and did not align, I put about 15,000 miles on each one(approx). No excessive tire wear. My current Z I went with longer bolts and cut the front bushings. I drove it for two weeks then went in for an alignment. The front end guy said it was way out of alignment. :cheers:
Old Aug 4, 2003 | 12:39 PM
TopCat's Avatar
TopCat
Default Re: just lowered c5 how long till alignment (racer44)
Has anyone checked alignment before AND after lowering :confused:
Seems that would be the only way to stop the debate :yesnod:
If anyone has, please let me know. I don't want to shell out another $75 and risk scratches on my wheels (like they put on my wagon wheels :cuss ) for nothing when I lower mine.
:cheers:
Old Aug 4, 2003 | 01:53 PM
sick_vette's Avatar
sick_vette
Default Re: just lowered c5 how long till alignment (TopCat)
I lowered mine on stock bolts. Waited a couple hundred miles then took it in. It was fine, but they still charged me anyways :mad
I think if you keep the stock bolts you will be alright. But it is a piece of mind.
Old Aug 4, 2003 | 04:45 PM
BSiegPaint's Avatar
BSiegPaint
St. Jude Donor '06-'07
:cheers:
:iagree:
It wasn't until I took off my stock tires that I saw the front tires were terribly out of alignment. Wore right through to the threads on the inside 2" of the tires with no outward sign of misaligning (pulling one way or another). I guess I would be a candidate to do just this. I've had a recent alignment and need to lower my car... :thumbs:
Old Aug 4, 2003 | 09:05 PM
John Shiels's Avatar
John Shiels
From: Buy USA products! Check the label! Employ Americans
It will change the alignment. I drove about 300 miles before I realigned it after I was sure I liked it.
Old Aug 4, 2003 | 11:28 PM
Busa196's Avatar
Busa196
I lowered mine to 26 &1/2" in the rear and 26" in the front.....pretty damn low. It's been that way for about 1k miles, the car doesn't pull either way and handles beautifully......I've checked the tires and all seems good. I'm not going to fix "what aint broke." :thumbs:
To just lowered c5 how long till alignment
