brake ?
Old Aug 4, 2003 | 10:20 AM
lowprofiling's Avatar
lowprofiling
Default brake ?
i posted this in general by mistake
any problem fitting a set of OEM front rotors, and calipers on the rear? The stocks look to small. I know some are going to chime in and say get the Eradispeeds, but for me cruising around the local streets I really can find better things to spend $600-$800 on. I was thinking factory set up on the back and powder coat the calipers and can have a nice look at a good price. thanks
Old Aug 4, 2003 | 11:03 AM
carpe dm's Avatar
carpe dm
Default Re: brake ? (lowprofiling)
Save your money; GM spent a lot of it engineering the brake system. Perhaps if you coated/painted them they would not look "to" small. :rolleyes:
Old Aug 4, 2003 | 11:18 AM
vetterdstr's Avatar
vetterdstr
CA Events Coordinator
I agree that the brakes look small. You can install the front brake system on the rear, many have already done it. There are some down sides to it though...
vetterdstr :cheers:
Old Aug 4, 2003 | 11:30 AM
lowprofiling
Default Re: brake ? (vetterdstr)
vetterdstr-
a few downsides? such as ????
Old Aug 4, 2003 | 11:38 AM
vetterdstr's Avatar
vetterdstr
Loosing your parking brake, having the brake bias off because of the diff calipers and larger rotor. If you want to get serious about switching your brakes, buy a proven kit that wont give you any of the downsides that I talked about.
vetterdstr :cheers:
Old Aug 4, 2003 | 11:45 AM
lowprofiling
i was thinking the car may brake diiferent because of the larger rotor. thanks for the info. maybe best to leave alone, or just change the caliper. :cheers:
Old Aug 4, 2003 | 12:05 PM
vetterdstr's Avatar
vetterdstr
:cool: :cheers:
vetterdstr :chevy
To brake ?
