Please clear this up...Need injector advice.
Aug 4, 2003 | 01:11 PM
I have heard conflicting stories about the ratings for injectors over the years.
IS this info correct?
1997-1998 Corvette & F-body 28lbs
1999-2000 Corvette & F-body 26lbs
2001-2003 Corvette & F-body 28lbs
What are Z06 injectors rated at?
I have a 99 and doing a scan while racing my injectors were at %95
I need new ones before a tune but need to know which to get.
Thanks! :cheers:
Aug 4, 2003 | 10:25 PM
Re: Please clear this up...Need injector advice. (fdupny)
Anyone have an answer?
Aug 4, 2003 | 10:52 PM
If your at 95% for a short time at peak RPMs it's no problem. But if your basically stock and need to, get a set of 01-03 stockers(Z06 are the same). You can buy low mileage ones cheap. The next popular inj. are SVO 30's. Too big injectors will make it harder to lean your AFR.
Aug 4, 2003 | 10:56 PM
I can't say if this holds true for f-bodys but:
'97-'98 28.4
'99-up 26.4
ZO6 28.2
SVO30 36.12
[Modified by SFVetteman, 8:02 PM 8/4/2003]
Aug 5, 2003 | 01:24 AM
Re: Please clear this up...Need injector advice. (SFVetteman)
'97-'98 28.4
'99-up 26.4
ZO6 28.2
SVO30 36.12
Correct on vettes...
Aug 5, 2003 | 06:52 AM
Re: Please clear this up...Need injector advice. (PaceThis)
01-03 LS1 and Z06 are 28 lbs.
Aug 8, 2003 | 04:27 AM
Re: Please clear this up...Need injector advice. (jfpilla)
Looking at my parts manual, (this time with my glasses on) I see this is correct :cheers:
[Modified by SFVetteman, 2:47 PM 8/8/2003]
Aug 8, 2003 | 07:30 AM
Put in some #30 Injectors.
They flow #36 at our fuel pressure.
I had them and was very happ with it.
You can get them from chris@speeddemonmotorsports and other forum vendors.
Hope that helps,
Michael
