Would 1.8 or 1.85 rockers help my current setup?
Old Aug 5, 2003 | 06:22 PM
xSSv's Avatar
xSSv
Default Would 1.8 or 1.85 rockers help my current setup?
I have a 98 with the 02 LS6 cam (the one with the .550 lift), ls6 intake, headers, offroad ypipe and 3500 stall.
Anyhow, I was wondering what kind of gains I'd see with rockers and which ones to get. I have the comp 918 springs too.
I read that the slp 1.85's would give me .600 lift and wonder if I'd have any valve clearence issues or "valve float".
I have the rev limit set at 6500 and the shift points set at 6250.
I run 12.20 now and would like to get into the 11's off the bottle.
Any input is appreciated.
Anyone have rockers on a ls6 cam? Thanks.
Old Aug 5, 2003 | 06:31 PM
Lashtal's Avatar
Lashtal
Default Re: Would 1.8 or 1.85 rockers help my current setup? (xSSv)
Well, I'm not sure if you would see too much gain off of the difference.
If you swap out the Heads with a set of Stage II's and get a set of rear-end gears like the Z06 then you should be able to hit the 11's.
Careful with NOS. The wrong A/F NOS mixture could have bad effects. Proper tuning on a dyno would be the best thing overall - esp. if you change heads, etc.
Keep us posted on the results!
Btw, post a pic of your Vette! :D
:cheers:
Old Aug 5, 2003 | 06:38 PM
xSSv's Avatar
xSSv
Default Re: Would 1.8 or 1.85 rockers help my current setup? (Lashtal)
I'd like to get gears some day; but really don't want to shell out that much money right now. I can pretty much do anything with an fbody; but damn, these vette's are completely different in the tranny and rearend.
I want to get some feedback before I spend $425 for rocker arms. They're a mod that I can easily install myself; where a rearend looks kinda difficult.
At least in a vette, it is easy to change the spark-plugs where they are a PITA in a fbody. :D
To Would 1.8 or 1.85 rockers help my current setup?
