another battery leak
Old Aug 5, 2003 | 10:11 PM
NEPTUNEBILL's Avatar
NEPTUNEBILL
Default another battery leak
Well I had the alt bench tested as ok the new battery was ok, I could not get a clean read from the alt cable to the battery, moved the box and found where the old GM battery had leaked and corroded the cable, why would GM sell us a 50K car with a 10 dollar battery I would have been glad to 50,100 dollars and not have to deal with replacing the wiring--there have been many post on this yet they still use this pos battery, I suggest even if you just bought a new c5 swap the battery immediately---
Old Aug 6, 2003 | 12:20 AM
SpinMonster's Avatar
SpinMonster
Default Re: another battery leak (NEPTUNEBILL)
Bill, perhaps with your corvette luck, you should consider a honda civic
