Sway Bar End Links
Old Aug 5, 2003 | 11:39 PM
ILVET's Avatar
ILVET
St. Jude Contributor
Default Sway Bar End Links
The part number for metal end links for C5's is 10435298 and run in the neighborhood of $14 at GM Parts Direct. Parts Direct also has another part number for end links of 10424745 that runs $37. Does anyone know what this end link is? Thanks.
Old Aug 6, 2003 | 01:15 AM
SHOWTIME!'s Avatar
SHOWTIME!
Default Re: Sway Bar End Links (Hildy)
I'm guessing the 37.00 dollar one is metal
Old Aug 6, 2003 | 01:30 AM
KingTut's Avatar
KingTut
Default Re: Sway Bar End Links (SHOWTIME!)
$37 - Steel as used in Z51 packages
$14 - Aluminum - more recient for use in Z06 - considered equally strong and lighter weight than the steel - and cheaper also.
Plastic - base stock.
Old Aug 6, 2003 | 04:10 AM
NastyC5's Avatar
NastyC5
Hildy I have a set of steel end links I'll sell you cheap ;)
Email me if if your interested.
nastyrt10@aol.com
Old Aug 6, 2003 | 01:21 PM
Miaugi's Avatar
Miaugi
A word of warning! :cry
GM Parts Direct has a non-existant customer service policy! :mad
If you have any problems they totally ignore you! :banghead:
Call Fichtner instead. Here's their link! :thumbs:
http://www.corvetteforum.net/c5/kenf...rtspage1.shtml
Old Aug 6, 2003 | 01:37 PM
c5chris's Avatar
c5chris
Default Re: Sway Bar End Links (KingTut)
Are you sure the $14 ones are the aluminum kind? It might be the base plastic.
BTW, why would the sway bar end links be made of plastic? It just makes sense to have them made of metal too since the sway bars are subject to flexing and compression during cornering. :confused:
Anybody notice a difference with the steel or aluminum ones?
Old Aug 6, 2003 | 02:33 PM
xtream1's Avatar
xtream1
From: Stealth So Cal GOCC ...comming to invade your neighborhood soon
Default Re: Sway Bar End Links (c5chris)
I had the '02 Z51 package and the links were Aluminum. My best guess is that the $37 links are Aluminum, and the $14 links are the plastic ones that came on the base model.
Old Aug 6, 2003 | 03:30 PM
KingTut's Avatar
KingTut
Are you sure the $14 ones are the aluminum kind? It might be the base plastic?
From Ken Fitchner's parts newsletter:
Front or Rear Aluminum Links $ 17.97 ea
Front or Rear Steel Links $ 49.61 ea
10423035 Plastic
10424745 Steel
10435298 Aluminum
That should establish the price points for the two "replacement" types as I do not know anyone who would not use the aluminum ones over the "stock" plastic ones.
As for GM Parts Direct - They stock nothing - they just get dealers to ship you the stuff. If they do not ship the same part you ordered - wou will get good service. If YOU had the wrong part number - too bad for you.
Fitchner holds your hand and helps you be sure you get the right stuff, for that there is a small extra fee over GM Parts Direct. Sort of like buying retail and wholesale. Wholesalers do not put up with tire kickers or uneducated buyers like the retailers do - that is why there is a price difference.
I have a parts CD cost about $6.00 and it has all the correct numbers. They are frequently on eBay.
[Modified by KingTut, 4:27 PM 8/6/2003]
Old Aug 6, 2003 | 03:37 PM
Elk's Avatar
Elk
One would think so, but through 2001 the rear sway bar end links were plastic. You can see the deformation just looking at them even with the car sitting still. The swap is very easy and at least made me feel better. Frankly I'm not sure if it made any real difference, even on a road course. OTH, GM would not have used aluminum on 2002 on up if it didn't matter as I'm sure they're more expensive then plastic.
BTW, GM Parts Direct has perfectly fine customer service. I've resolved a couple issues with them with no difficulty. OTOH, use Ken Fichtner whenever you can and support our sponsor.
Old Aug 6, 2003 | 05:44 PM
vetteshop's Avatar
0vetteshop
Former Vendor
St. Jude Donor '13
10424745 is discontinued :yesnod: If you go to "check out" you will see that 10424745 changes to 10435298,which is the aluminum link at $14 ;)
Old Aug 6, 2003 | 11:18 PM
ILVET's Avatar
ILVET
Hello Ed,
The new links are cast aluminum. GM Parts has even discontinued the
steel links for the aluminum links. We have them in stock, they list for
23.96 ea and your cost is 17.97 ea.
Bob Wendorff
Parts Manager
Fichtner Chevrolet
Laurel MT
406-628-4618
Old Aug 7, 2003 | 05:38 PM
jjcslynn's Avatar
jjcslynn
I have a pair of BRAND NEW plastic end links I'll sell for $15 for the pair plus shipping.
Old Aug 7, 2003 | 09:08 PM
jawsski's Avatar
jawsski
Default Re: Sway Bar End Links (jjcslynn)
I got Z51 and end links ain't steel..they're plastic
[Modified by jawsski, 9:09 PM 8/7/2003]
Old Aug 7, 2003 | 10:18 PM
LoneStarFRC's Avatar
LoneStarFRC
Default Re: Sway Bar End Links (jawsski)
That's because that's what came on the 99's.
Old Aug 7, 2003 | 11:45 PM
ILVET's Avatar
ILVET
I ordered part #10435298 from my dealer yesterday thru the body shop and picked them up today. They are aluminum.
Old Aug 11, 2003 | 02:49 PM
saber's Avatar
saber
:iagree:
Old Aug 12, 2003 | 08:48 AM
bradfordjr's Avatar
bradfordjr
The Z51 cars have metal end-links in the front and plastic end-links in the rear. All non-Z51 cars have plastic end-links both front and rear. Beginning with the 2002 model year, GM changed to aluminum all around. :yesnod:
To Sway Bar End Links
Old Aug 12, 2003 | 06:35 PM
LoneStarFRC
Default Re: Sway Bar End Links (bradfordjr)
Nope. :nono: Gotta disagree here. I have a '99 w/Z51 and they are plastic front and rear.
The info I have is:
Z51 suspension '97-'99: plastic front and rear
Z51 suspension '00-'01: steel front, plastic rear
Z51 suspension '02 (and '03-'04 I believe): aluminum front and rear
Old Dec 18, 2012 | 07:01 PM
Jesse Asis's Avatar
Jesse Asis
The plastic links work fine for the stock sway bar setup on stock vettes. As you increase the sway bar thickness and push the handling, the plastic links can't really handle the stress, so metal or aluminum is needed. If you upgrade your sway bars to either the Z51 or Z06, it is advisable to upgrade to the aluminum links as the stress could break the plastic on track or spirited driving due to less flex on the thicker sway bars... GM is giving the mininum here, you want to track your vette, you have to upgrade accordingly at your cost.. No salesman ever told me my stock vette was ready for the track.. Good luck, I install my Z06 sway bar with aluminum links this coming Sat. (depending on the weather, it's cold in my garage)... Later
Old Dec 18, 2012 | 09:10 PM
thmehr's Avatar
thmehr
I so happy that you guys are highly recommending Fichtner Chevrolet. They are only 20 miles away from my home.
