Radiator fluid
Old Aug 6, 2003 | 09:50 AM
Nixs99's Avatar
Nixs99
Default Radiator fluid
I have a 99 vette, it has 46,000 on it. I never changed the radiator fluid in it. I am fearly mechanical. Is it easy to due, if so can anyone explain to me how to do it. Thanks :skep:
Old Aug 6, 2003 | 10:55 AM
luvinc5's Avatar
luvinc5
Default Re: Radiator fluid (Nixs99)
It's not hard but if you do it yourself, you will have to do a few fill/drain cycles to remove all the existing coolant.
I brought mine to my mechanic for a machine flush/exchange. It's way easier and you get 99% of the old coolant out of your system.
My other advice is to use distilled water to avoid sludge development (no dissolved mineral interaction with the coolant).
