I just recv'd my set. I've heard the progression of performance goes z06<hotchkis<bmr<t1. but honestly I have no clue, that's just what I've heard. I'm looking forward to finding out though!
I got the front shocks (bilstein sports) and sway installed, didn't have time to do the rears. noticed a subtle improvement, a little tighter feeling. will completing the rear end make a huge difference? should I also upgrade the springs?
Re: Sway bars (Red Gump)
I've done some research and found that to be true.
Even though the BMR and hotchkis bars are the same diameter, the BMR have slightly shorter "Arms" which result in a stiffer torsional rate.
IMHO the T-1 bars are too stiff for comfortable street use, but work very well on the track.
We are developing a set of adjustable bars for the C5 that when set on full soft would result in Z06 torsional rate and on full stiff would approach T-1 rating.
