MAT screen
Old Aug 7, 2003 | 11:44 AM
Sweet98's Avatar
Sweet98
Default MAF screen
Is it worth removing the screen on this?
Yes the MAF screen, my mistake, thanks
[Modified by Sweet98, 5:03 PM 8/7/2003]
Old Aug 7, 2003 | 11:48 AM
lowdowndirty's Avatar
lowdowndirty
Default Re: MAT screen (Sweet98)
If you're refering to the Mass Air Flow sensor (MAF meter), then it depends on who you ask. Many members have reported gains and the mod is extremely easy (just disassemble the sensor and push out the screen with your thumbs). If I'm correct, the later C5's came with no screen, including the Z06. Otherwise, I don't beleive there's any type of "screen" on the air temp sensor.
Old Aug 7, 2003 | 12:04 PM
Sweet98's Avatar
Sweet98
Default Re: MAT screen (lowdowndirty)
My 98 has it, i dont know if I should bother to remove it.
Old Aug 7, 2003 | 12:32 PM
TopCat's Avatar
TopCat
Some have experienced driveability problems, others report SOTP power increases. As a low budget modifier, I plan on removing mine and porting it best I can, as well as porting the throttle body. I guess it's a gamble. I might end up with problems and have to replace the modified MAF. It's a chance I'm willing to take to try to open up the flow a little more. The 'screen' is a honeycomb flow straightener that really blocks the flow. I imagine it'll take 40-60 miles of driving for the computer to re-learn for the new flow, similar to a new air filter/intake.
My 2 cents for what it's worth.
Old Aug 7, 2003 | 02:07 PM
Sweet98's Avatar
Sweet98
Default Re: MAT screen (TopCat)
Hey , what do you mean "for the computer to re-learn the flow" what does that do? I did the zip tie mod the other day.
Oh yea, and what drivability problems
[Modified by Sweet98, 7:07 PM 8/7/2003]
Old Aug 7, 2003 | 02:12 PM
Jack Behrle's Avatar
Jack Behrle
Default Re: MAF screen (Sweet98)
Removed mine in 10 minutes, noticed slight improvement in top end and no difference in drivability.
From previous threads, it is a bit of a crap shoot.
Old Aug 7, 2003 | 02:15 PM
Sweet98's Avatar
Sweet98
Default Re: MAF screen (Jack Behrle)
Is that what gave the new coupes that extra 5hp from 345 to 350? Or is that something else?
Old Aug 7, 2003 | 06:43 PM
BSiegPaint's Avatar
BSiegPaint
St. Jude Donor '06-'07
I think most of the 5 hp came from the change in the intake to the Z06 manifold... Lots of threads on removing the screen; you can search all night long. I suppose it depends on where you drive and how often. I use my car every day, to and from work on good and not-so-good streets. When I recently removed my stock airbox for an aftermarket replacement, I found the screen covered with all kinds of crap that had missed the filter. Glad I had the screen after seeing that!
Old Aug 7, 2003 | 07:25 PM
C5kid's Avatar
C5kid
Cruise-In VI Veteran
St. Jude Donor '12
Default Re: MAF screen (BSiegPaint)
I wouldn't do it!!! Did it to mine and screwd the A/F ratio all up, runs really lean at lower RPM's and Super Rich at the top end
Old Aug 7, 2003 | 07:48 PM
Guest
Guest
Posts: n/a
Sweet,
That means an idle re-learn sequence (after a mod) so the computer can sense the newer or bigger MAF. Kinda rebootin' and plug-n-play. There are some Tech Tips here on the procedure if I'm not mistaken...I had to do it.
As far as the screen thing, I think it's all BS. Does anyone really think they're going to gain anything significant by taking out a screen? Only deep pockets work with Vettes and the like (IMHO).
Old Aug 7, 2003 | 07:52 PM
Scubanme's Avatar
Scubanme
The later model C-5s got updated intake manifolds and exhaust manifolds that are Z06 items. You can see a picture of the Z06 exhaust manifold on
the "West Coast" forum vendor site. Compare it to your exhaust manifold.
The difference in the intakes are almost impossible to see without a side to side comparison.
To MAT screen
