Greenish/Brown Sludge...
What do I need to do to get rid of this stuff for good? Is there some additive that I can add to dissolve it?
Thanks!
If they put the old style stuff in, then you're going to have to completely flush out the system and refill with DexCool.
I sure hope I'm wrong.
Mike
Bill
Mike
Thanks again!
I would have a competant shop flush and clean the system and replace with new. They should not use the sealing tablets or any sealant additive.
Good catch, you have perhaps saved yourself a bigger problem.
Pete
Thanks again!
Drain all the old stuff out, and fill with water. Run the engine long enough to make sure the system is full, then go drive it until you get up to operating temps (190-200). By driving it you vary the rpm (and therefore the fluid flow rate through the system) which will do a better job than just letting the engine idle. Then let it cool down and drain that out.
You might even have to do that a few times until the drained water looks relatively clean. Once it is, then refill with 50% DexCool and distilled water. You can get it at any supermarket or Wal Mart. NOT spring water or anything else but DISTILLED water. Otherwise all the minerals in the spring or tap water will plate out into the cooling system. (ask me how I know :rolleyes: )
Oh, BTW, the radiator drain doesn't screw out, just turns about 90 degrees and pulls out.
HTH, and have a good one,
Mike
