Noise in first gear
Old Aug 8, 2003 | 01:33 PM
Silver99's Avatar
Silver99
Default Noise in first gear
Just bought a Silver 99 Coupe and I am very happy with it so far. Just have one concern about a noise I am hearing. As soon as I let out on the clutch in first gear from a stop I hear a noise that I can only describe as a gear whine. It's not loud and I only hear it in first, not any other gear. I thought I read somewhere that this is normal for the C5. I would appreciate any info others might have on this.
Old Aug 8, 2003 | 03:31 PM
lowdowndirty's Avatar
lowdowndirty
Default Re: Noise in first gear (Silver99)
I know I'm not much help, but I can say I've never heard the noise you're describing. (99 M6 hardtop.)
Old Aug 8, 2003 | 04:24 PM
adame780's Avatar
adame780
what sorta pitch does the sound have?
high whining?
Old Aug 8, 2003 | 05:42 PM
Silver99's Avatar
Silver99
Default Re: Noise in first gear (adame780)
It's not really a whine, more like just gears meshing, but it's louder then you would think is normal.
Old Aug 8, 2003 | 06:00 PM
C5Cemo's Avatar
C5Cemo
If it sounds like marbles in a can, it's normal...created by the torque tube arrangement.
Old Aug 8, 2003 | 06:01 PM
gonbad's Avatar
gonbad
Default Re: Noise in first gear (C5Cemo)
:iagree:
Normal to the point they discuss it in the owners video.
Old Aug 8, 2003 | 06:41 PM
Silver99's Avatar
Silver99
Default Re: Noise in first gear (gonbad)
Didn't get a video with the car since I bought it used. Do they actually have a sample of what it sounds like on the video?
Old Aug 9, 2003 | 05:47 PM
fmYellowWRX's Avatar
fmYellowWRX
Default Am I Paranoid? I've got a noise also - AE 03 MN6
I have a 03 AE with 236 miles. I was asking the same question a while ago and didn't get many answers. Here's what mine does:
When I release the clutch from a stop, there is a lower frequency noise that does sound like marbles in a can. It lasts a half a second. This noise is on the owner video and doesn't worry me at all.
The other noise I'm trying to get some feedback on is a higher pitch course whine that I hear mainly in the first three gears. The pitch increases across a fairly narrow range as the RPM of the motor rises. I can hear it best with the AC off, radio off and the passenger window cracked or fully open. The noise seems to come from underneath the car near the center. At light or part throttle it is most noticeable as the motor sound drowns it out under moderate or more throttle. The noise continues as long as the car is moving more than 5-10 mph, even with the clutch pedal depressed but does stop when I put the car in neutral with the car moving. The noise is not a turbine smooth whine (like straight cut gears) as there is some courseness but I would not describe it as grind. The pitch is higher than the noise I hear when I release the clutch from a stop. The volume level is such that any noise in the cabin from the AC, stereo or wind noise from the top being off drowns it out.
Anyone else have the same thing? Am I being a paranoid new Vette owner?
I appreciate any input anyone has!
:confused:
Old Aug 10, 2003 | 12:19 AM
Silver99's Avatar
Silver99
Listened to the sound again today and a I believe it is the "marbles in a can" sound described by others. Thanks to everyone who responded for the info.
Old Aug 10, 2003 | 01:14 AM
FunDriver's Avatar
FunDriver
Veteran: Marine Corps
FmYellowWRX...maybe one of the techs on the Forum will be able to help more but I'm wondering if it might be the synchros. I'm not a mechanic but it seems that if it's not too loud, and is there except when in neutral, maybe that's what it is.
As far as the sound in first just starting out, I have the same thing. It's nothing to worry about. Sometimes mine is louder than at other times, but I've heard and read enough about it to understand that it's normal in the C5 transmission. It only happens in 1st, and even then just when you're taking off, right? Mine's been doing it for a long time and no problems.
Old Aug 10, 2003 | 10:56 AM
fmYellowWRX
Default Re: Noise in first gear (FunDriver)
Thanks for the input!
The marbles in the can thing is not bothering me. It appears to be the same on all MN6's.
I was thinking the whine was either the syncros or a bearing on the input shaft of the transmission. I'm going to have it checked out.
Old Aug 11, 2003 | 12:09 AM
TXNC5's Avatar
TXNC5
Took mine back to the dealer twice before somebody convinced me it was normal. 1st is the only gear I ever heard it as well. The best way to overcome that noise is to modify it until you can't hear it anymore.
To Noise in first gear
