codes?
Old Aug 8, 2003 | 02:07 PM
rando's Avatar
rando
Default codes?
I brought up some codes and need some help with them. Codes PO161 and PO160 are O2 sensors for bank2 sensor2-b. What side of the engine are these sensors located on. The other code is P1571, ASR-desired tourque-c. What is a ASR and where is that located and is it and easy fix? The last code is BO361 which is Left Actuator feedbank short to ground. What is it,where is it and is it an easy fix?
