E-Brake help. Squeaks after rotor install....
Old Aug 10, 2003 | 09:44 PM
Tally Ho's Avatar
Tally Ho
From: Out Where the Buses Don't Run, Eglin AFB/ Niceville FL
2022 Corvette of the Year Finalist -- Modified
2021 C6 of the Year Winner - Modified
2020 C6 of the Year Finalist - Modified
Default E-Brake help. Squeaks after rotor install....
I just changed out my rotors and now the left e-brake makes a squeaking noise. Is there an adjustment and does anyone have a detailed picture of exactly how the wire spring goes back on? The spring popped out when I pulled the rotors and the rotors were a bear to get off. I'm not getting any excessive heat but pieces of the e-brake lining are chunking off. TIA to any and all replies. :flag :seeya
Old Aug 11, 2003 | 10:17 PM
Tally Ho's Avatar
Tally Ho
Default Re: E-Brake help. Squeaks after rotor install.... (3XBlack)
Anybody??? Car is up on jacks. Need some help here. Thanks. :flag :seeya
Old Aug 12, 2003 | 05:23 PM
OmVette's Avatar
OmVette
You know is just did all that...new rotors and new studs....
If your ePad is flaking better just to get new ones....
In regards to the spring... are you talking about the U shaped spring which holds the ePads to the e-brake plate (dont know exact name)?
If so, the spring holds the ePads up against the ePlate. Email me and mybe I can draw something up for you...but of course the Service Manuals (which are a must have) detail the installation.....
manny
Old Aug 13, 2003 | 06:35 PM
Tally Ho's Avatar
Tally Ho
Default Re: E-Brake help. Squeaks after rotor install.... (OmVette)
Got it fixed.
Thanks Manny for the help you offered.
Thanks Patches for the photo in another e-brake post.
:flag :seeya
To E-Brake help. Squeaks after rotor install....
