Service Traction Control, ABS System Codes
Old Aug 11, 2003 | 03:31 AM
teeceemv's Avatar
teeceemv
Default Service Traction Control, ABS System Codes
Nearly everytime I turn right and uphill out of my street (there is a slight curb there) , I get that stupid message on the DIC. After I turn the car off and re-start, it clears and everything is fine. This is driving me nuts. Anyone have a clue why this is happening? I don't see any visible problem, and it has never happened in any other circumstance.
Old Aug 16, 2003 | 02:58 AM
teeceemv's Avatar
teeceemv
Default Re: Service Traction Control, ABS System Codes (teeceemv)
Anyone?
Old Aug 16, 2003 | 04:00 AM
mapman's Avatar
mapman
Codes?
Old Aug 16, 2003 | 10:45 AM
BSiegPaint's Avatar
BSiegPaint
St. Jude Donor '06-'07
Check your codes to confirm the exact error. Sounds like a sensor has gone bad, like the Steering Wheel Position sensor. Just shooting from the hip here - the codes will tell you exactly what is wrong.
Old Aug 16, 2003 | 10:56 AM
ROD BROWN's Avatar
ROD BROWN
I had the same problem last week and it was the right Front sensor.I had the sensor/hub replaced and it cured the problem.I hope you have a fat check book,its not cheap! :chevy :chevy :flag :chevy :chevy
Old Aug 16, 2003 | 11:04 AM
vetterdstr's Avatar
vetterdstr
CA Events Coordinator
It could have to do with the wheel speed variation code.. In which case replacing a wheel bearing would be the cure. What are the codes?
vetterdstr :cheers:
Old Aug 16, 2003 | 03:11 PM
jjcslynn's Avatar
jjcslynn
I get the same thing, but only when I've been driving a while and I hit a bump. I'm hoping its the wiring. Codes point to front right.
Old Aug 16, 2003 | 04:45 PM
ITSovr4U's Avatar
ITSovr4U
Default Re: Service Traction Control, ABS System Codes (jjcslynn)
My 99 did the same thing and the code was low system voltage, Had battery tested it was bad. replaced it this morning and the only problem now as posted on forum is the active handling warming up message. Get your battery tested if you get low voltage code to abs. John :cheers:
To Service Traction Control, ABS System Codes
