active handling question
Old Aug 11, 2003 | 06:38 PM
20vette01's Avatar
20vette01
Default active handling question
I turned active handling off today, pulled out and got completely sideways and all of a sudden the car felt like it missed a beat and allowed me to straigten it out. Why did this happen if I turned the active handling off. Something else I should look for?
Old Aug 11, 2003 | 06:51 PM
Net Exploit's Avatar
Net Exploit
Default Re: active handling question (20vette01)
I am going to venture a guest. Perhaps the Rev-Limiter cut in?
:eek:
Old Aug 11, 2003 | 06:52 PM
Radiant Heat's Avatar
Radiant Heat
I'm definitely no expert, and please correct me if I'm wrong, but I believe active handling can be off while traction control is still on. "Competitive Driving" mode is when they're both off. If that's correct, then maybe the traction control is what engaged and ended your tire spin. Just my $.02
Old Aug 11, 2003 | 06:57 PM
00TORCHCOUPE's Avatar
00TORCHCOUPE
Default Re: active handling question (Radiant Heat)
Competitive Mode is when active handling in on and traction control is off. This allows help in controlling your car and allowing you to spin your tires at the same time.
Old Aug 11, 2003 | 08:02 PM
ICULUKN-C5's Avatar
ICULUKN-C5
Default Re: active handling question (00TORCHCOUPE)
:iagree: :iagree: I am voting for rev limiter
Old Aug 11, 2003 | 08:07 PM
Bink's Avatar
Bink
Cruise-In V Veteran
St. Jude Donor '09
If it fell on it's face then it's" Abuse Mode". PCM turns off 3 or 4 injectors in respnse to "Abusive " manuevers. Shifting gears at high throttle angles is one type of abusive manuever. Interestingly it doesn't occur when powershifting but does when speedshifting - must be related to throttle position changes (Delta). High throttle angle and selectind reverse is another abusive manuever....it's in the Helm's manual (PCM Section) ...I'm not making this up! :lol: :lol: :lol: :thumbs:
Old Aug 11, 2003 | 08:32 PM
20vette01's Avatar
20vette01
I failed to mention that the car is an A4 and only does this when im sideways. I wasnt close to the rev limiter. It seems like the car abrupty
cut power to gain control. I had control was just trying to do a cool power slide.
Old Aug 11, 2003 | 09:33 PM
Cary's Avatar
Cary
Maybe it was your Torque Management system? IMHO, I'd leave the Active Handling on all the time. Maybe you disengaged the TCS & the AHS was stll engaged, dunno.
Old Aug 11, 2003 | 10:19 PM
fast2000vette's Avatar
fast2000vette
Default Re: active handling question (ICULUKN-C5)
It sounds like traction control kicked in. I hate that feature and turn it off everytime I start the car, but when I forget it sounds like what you explained. I don't have active handling so I do not know if there is a seperate switch or something that turn each off seperately.
:seeya :lurk:
Old Aug 12, 2003 | 05:03 AM
Oskee's Avatar
Oskee
Veteran: Marine Corps
I woud say your Traction Controll kicked in by powering down the motor as soon as it detected a loss of traction in one of the wheels. I have tryed the same thing in my Y2k, unless I turn both AH and TC off its hard to spin the tires !! :smash:
To active handling question
