Getting a Re-ring: What mods to add?
Old Aug 11, 2003 | 11:25 PM
Garibaldi's Avatar
Garibaldi
Default Getting a Re-ring: What mods to add?
Hello:
Assuming a willing dealer and a competent technician (hold that thought...:crazy:) what mods could be installed without too much added labor? No heads. I'm thinking cam package, headers, exhaust. Suggestions or caveats?
Regards,
Garibaldi
Old Aug 11, 2003 | 11:34 PM
Scubanme's Avatar
Scubanme
Default Re: Getting a Re-ring: What mods to add? (Garibaldi)
NOw is your big chance.....Cam and heads for sure! true roller timing chain.
LS-6 intake if your car is earlier than a 2001. Run don't walk! :flag
Old Aug 11, 2003 | 11:40 PM
'97 C5's Avatar
'97 C5
Default Re: Getting a Re-ring: What mods to add? (Scubanme)
:iagree:
Old Aug 11, 2003 | 11:56 PM
Gary2KC5's Avatar
Gary2KC5
Default Re: Getting a Re-ring: What mods to add? ('97 C5)
H/C, under drive pulley.
Upgrade the clutch, m/c, & slave if they pull the engine.
You will save soo much by doing the H/C now.
Old Aug 12, 2003 | 12:01 AM
Sack Rat TT's Avatar
Sack Rat TT
[QUOTE]mods could be installed without too much added labor? No heads. I'm thinking cam package, headers, exhaust. Suggestions
:iagree: Cam is worth 25-35rwhp, headers worth 10-12rwhp. Do not go too wild on the cam. If you do not do head porting/new valves at least do freshen up the existing valves and seats etc. The cam will require different valve springs as well. The suggestion of replacing the intake with later ZO-6 is worth another 8-12 rwhp on the early model cars. Exhaust/mufflers add another 3-4rwhp. You will not be dissapointed if all these suggestions are accomplished. Good Luck
:smash: :smash:
Old Aug 12, 2003 | 06:29 AM
CJS's Avatar
CJS
My dealer did my engine and exhaust mods in the sig for $500 extra, it ran perfect without tuning. :D
Old Aug 12, 2003 | 09:08 AM
vetterdstr's Avatar
vetterdstr
CA Events Coordinator
Forged pistons, new HP rings, forged rods, Cam & HD clutch setup... From there you can add anything later and be set!
vetterdstr :cheers:
To Getting a Re-ring: What mods to add?
