Check engine light and code P0300
Old Aug 12, 2003 | 04:01 AM
C5 Frederik's Avatar
C5 Frederik
Default Check engine light and code P0300
A friend of mine had a little race with a Ferrari on the autobahn. Now he has the "check engine" light on, and the DIC stored "P0300, engine misfire detected"
How can he get rid of the "check engine" light? Car runs fine so far. Any hints?
Thanks in advance
Frederik
Old Aug 12, 2003 | 04:53 AM
Oskee's Avatar
Oskee
Veteran: Marine Corps
Default Re: Check engine light and code P0300 (C5 Frederik)
Have you tried depressing the reset button after you bring up the code ??
It should clear the code and turn off the check engine light , but if it detects a miss fire again, the check engine light will reappear untill the fault is corrected ...... :smash:
Old Aug 12, 2003 | 08:57 AM
C5 Frederik
Default Re: Check engine light and code P0300 (Oskee)
OK, will forward this info, thanks
Frederik
Update: friend pushed reset and so far everything is fine. :cheers:
For warranty issues: will it still be shown at the dealer? Or is it gone for ever?
[Modified by C5 Frederik, 3:35 PM 8/12/2003]
Old Aug 12, 2003 | 10:21 AM
runamuk's Avatar
runamuk
Cruise-In V Veteran
St. Jude Donor '04
It's gone forever, unless the engine detects another misfire. :cheers:
To Check engine light and code P0300
