Clearing codes...
Old Aug 12, 2003 | 11:33 AM
C5North's Avatar
C5North
From: HOPE is the first step on the road to disappointment.
Default Clearing codes...
OK I had long tube headers installed and I'm getting an O2 code. While I'm waiting for the sims to come is there a way of clearing that code? It is disconcerting seeing the "check engine" light on all the time. Thanks.
Old Aug 12, 2003 | 12:18 PM
ryan0's Avatar
ryan0
Default Re: Clearing codes... (C5North)
hold option.. press fuel 4x.. find the code.. hold reset to clear it.
:cheers:
Old Aug 12, 2003 | 12:57 PM
Norris's Avatar
Norris
Is that an 1153 code? Also is it an H or C code?
Old Aug 12, 2003 | 02:01 PM
C5North's Avatar
C5North
Default Re: Clearing codes... (ryan0)
Thanks. That did the trick.
Old Aug 12, 2003 | 02:03 PM
C5North's Avatar
C5North
Default Re: Clearing codes... (Norris)
Had a couple "H" codes which I'm thinking might be from having the car on the dyno?? No "C" codes.
The O2 code being an issue was confirmed by Ward Sports. I'm sure it will come back but at least now I can clear it until I get the sims. The car is running pretty strong.
To Clearing codes...
