OEM Wheel Specs
Old Aug 13, 2003 | 09:54 AM
01sleeperZ's Avatar
01sleeperZ
5th Gear
Default OEM Wheel Specs
Can anyone tell me the offset and backspacing and weight of C5 wheels, both the thin spoke and the Z06 wheels? I can find data on the aftermarket ones, but I have not found it for OEM? :confused:
Old Aug 14, 2003 | 08:33 AM
C5 Frederik's Avatar
C5 Frederik
Default Re: OEM Wheel Specs (01sleeperZ)
I only had Mags and Z06 ones:
Mags offset front/rear: 60mm/65mm
Z06 offset front/rear: 54mm/56mm
With this you can calculate the backspacing= half rim width plus offset plus lip.
Mags backspacing front/rear: 6.8"/7.5"
Z06 backspacing front/rear: 7.1"/7.7"
Hope I did the math correct. Took 5mm for the lip.
Frederik
Old Aug 14, 2003 | 07:36 PM
01sleeperZ's Avatar
01sleeperZ
5th Gear
Default Re: OEM Wheel Specs (C5 Frederik)
Thanks! How do the wheels compare in weight, are the mag wheels any lighter?
Glen
To OEM Wheel Specs
