Knocking noise in steering
Old Aug 13, 2003 | 06:19 PM
~Sweet Cheeks~'s Avatar
~Sweet Cheeks~
Default Knocking noise in steering
Everytime I turn the wheel to the left I get one loud knock, but it only happens one time, each time I turn and it will happen no matter what directions the wheels are pointed. It sounds like it is coming from behind the steering wheel, maybe under the gauges.
The car is a 2001 A4 coupe and only has 3,800 miles on it. Any idea what this noise might be? Thanks for your help.
Old Aug 13, 2003 | 06:49 PM
allanlaw's Avatar
allanlaw
Default Re: Knocking noise in steering (~Sweet Cheeks~)
An incorrectly performed column lock recall repair??
Old Aug 13, 2003 | 07:02 PM
NassauBlue's Avatar
NassauBlue
Cruise-In VII Veteran
I've had something similar on my 98 for about a year. On my car it is not loud. I am more likely to feel a slight 'skip' in the steering wheel than hear it. It does not occur everytime I turn the wheel, but when it does occur, it is only when turning the wheel left.
Is there a difference in the sound level between when the engine is running and not running and when the ignition is on or off? On my car, it is loudest and occurs everytime I turn the wheel left when the key is in the RUN position with the engine not running.
Old Aug 13, 2003 | 08:40 PM
~Sweet Cheeks~
Default Re: Knocking noise in steering (allanlaw)
Never had it done, no need on an 01' A4. Honestly I usually have the music up where I could not hear it but I felt something so I turned the music down and I heard it last time I drove it. I wont be able to check it again until this weekend. Anyone else have this annoying noise? :confused:
Old Aug 13, 2003 | 10:19 PM
2KVetteMan's Avatar
2KVetteMan
This is just a guess it might be related, its worth a shot. https://www.corvetteforum.com/techti...D=35&TopicID=1
Let us know. :cheers:
To Knocking noise in steering
